Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: newly installed tacho and now car wont start
    89 VN 5lt
    Mar 2005
    Busselton W/A
    Angry newly installed tacho and now car wont start
    A little while ago I instlled a tacho on my car down by the gear selector but didn't like it there so I moved it to just above the middle vents on the dash.
    When I took it for a test drive the speedo and tacho kept dropping in an out then after a few mins she started farting around and stalling when ever I revved it, so I disconnected the tacho all together took it for another drive and just as I pulled into the driveway it stalled and hasn't started since I've even had the rac guy out to have a look an even he couldn't find anything It's getting fuel and has spark so everything is working there, this is the first time it really has me beat.
    What the hell have I done???
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Its prolly the lil thing that stops the car from starting when its not in Park or neutral.
    Not sure wat its called, but that would probly be the problem if u moved ya tacho from near gear shifter.
    ________________________________________
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    power wires from tacho shorting out? blew a fuse somewhere in the process of removing it?
    id say you've bodged some wires somewhere, with the speedo and tacho cutting out.
    give the gearshifter a wiggle while u try n start it, but that shouldnt kill speedo and tacho while driving.
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    Quote Originally Posted by calais_cruzin View Post
    park safety switch
    We got rep back, yaaay!
    89 VN 5lt
    Mar 2005
    Busselton W/A
    nah it's not that it was working fine when it was down by the gear shift. The engine will turn over but not firing like it's not getting fuel (but it is as there is fuel going around the injector rail), checked every fuse there is an they are all fine.
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by JD View Post
    park safety switch
    inhibitor switch. so its wired to your coil? probably a loose connection there i think, if it was the inhibitor switch then it wouldnt even crank.
    JD
    VS Berlina
    Aug 2006
    Deep South, SA
    ok, my mate used to call it that guess he was wrong.
    fabz's Avatar
    fabz is offline I Can Do Science Me
    Blown V6 VT commodore 5 speed
    Jul 2005
    In My Car!!
    Rewire it back they way you had it? See if it still wont start? Was it connected to a kill switch? Did you cut any other wrong wires? Does the car turn over?
    .:Blown VT V6, DAJ37:.
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    if all else failed you could take your dash out and check you haven't drilled into something, but it's a heinous job, so i'd look for all other options first
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    If you have it wired off the coil rather then from the dash wire, and it has earthed out the coil will not fire. Check that there is no loose or exposed connections.
    Selling FG G6E Turbo and buying a N/A Supra
    89 VN 5lt
    Mar 2005
    Busselton W/A
    yep I tried rewiring it back to how it was and still no go, there's no exposed connections that I could see, it was wired up to the tacho connection point by the left hand strut tower all I done was make the wires longer so it would reach up to the dash, it wasn't connected to the kill switch either it will turn over but just not start.
    an my friken finger tips are killing me I might go have a smoke an go an lay down and
    89 VN 5lt
    Mar 2005
    Busselton W/A
    Quote Originally Posted by AirStrike View Post
    would the coil be stuffed if this has happened?
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Quote Originally Posted by biteme1978 View Post
    no. but if you havent touched the coil then its probably not that. it could just be a co-incidence, once i thought i drained my battery by leaving the interior light on all day, so i jump-started it, then the battrey flattened after a short while. so went and bought a new battery and same thing happened, turned out to be the alternator...
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Quote Originally Posted by vn6pwr View Post
    Ummmm it's most likely wired off the neg of the coil.
  15. #15
    89 VN 5lt
    Mar 2005
    Busselton W/A
    well I have got a flat battery right now but I think thats just from trying to start it soo much, plus the rac guy had a booster pack and it still wouldn't start even with "start ya barstard"(it comes in a spray can) sprayed down the throttle body
  16. #16
    89 VN 5lt
    Mar 2005
    Busselton W/A
    I reckon it got jelous as I had a mates VT 5 lt here on saturday and I was playin around with that changing the leads and cleaning the throttle body. So I reckon she's chucked the ****s big time who says cars dont have a personality
  17. #17
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    I think the problem was you put a tacho on a berlina when it already has a perfectly good one in your dash!
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
  18. #18
    89 VN 5lt
    Mar 2005
    Busselton W/A
    Quote Originally Posted by STEALTHY View Post
    No it doesn't, Why would I put one on if it already had one??
  19. #19
    89 VN 5lt
    Mar 2005
    Busselton W/A
    I tried putting a new dash one in it ages ago but cause it was for a 6 an not an 8 it fried the wires in the new dash facia, but that was a few months ago.
  20. #20
    STEALTHY™'s Avatar
    Jan 2005
    settle down man, i was just assuming going by the barrage of other posts similar, when the person already has a tacho.
    It woud've bene cheaper for you to change to the level 2 dash, and you wouldn't have to cut or join a single wire.
    cheers sexy
  21. #21
    89 VN 5lt
    Mar 2005
    Busselton W/A
    Sorry if I sounded testy lol but it's got me buggered why anyone would want to put a tacho on the dash if there's already one the cluster
    being a berlina u would think it would have had one but then again there is sooo many things that are different to what it should be. for example on the heater pipes the heater valve that is in it now is for a 92 onwards V8 and mines a 89
  22. #22
    STEALTHY™'s Avatar
    Jan 2005
    my VP Berlina has cruise, power mirrors etc, but the tight arse who bought it new only got front power windows, a whole $300 more
    cheers sexy
  23. #23
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Wanna know why car wont start... First time you got it to ignition your car saw 10,000rpm on the gauge & had a heart attack!
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
  24. #24
    89 VN 5lt
    Mar 2005
    Busselton W/A
    Quote Originally Posted by HoZy View Post
    MaT
    lol hahaha nah cant be that as it was working alright before I tried to move it
    I think the berlina's in them days only come out with front electric windows HA mine doesn't even have them there's nothing berlina about this car besides where it says it on the dash.
  25. #25
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Did you drill into the dash? You may have drilled through the wiring loom... Which I also did Only broke 1 wire though luckily.
  1. Another VT that Wont Start
    By robbo5253 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-01-2008, 07:12 PM
  2. Car wont start, what to do?
    By VNSSMAN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-04-2007, 06:19 AM
  3. Help - Car wont start
    By COINERS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-04-2007, 11:01 PM
  4. newly installed 3 stage, with probs... help
    By yyg998vsute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2006, 09:07 PM
  5. VL wont start
    By kapiti holden in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-06-2005, 02:36 PM
