Results 1 to 24 of 24
Thread: Help with Injector Sizing - Program I made
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Default Help with Injector Sizing - Program I made
    I got board today so I whipped up a quick app for you all to work out what size injectors you need, or how much HP a certain injector can handle. Ill add more and maybe make it a bit prettier soon.
    Attached Files Attached Files
    Selling FG G6E Turbo and buying a N/A Supra
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Quote Originally Posted by nathans1987 View Post
    thats a nice little program, how did you make that?
    Good old Visual Basic. Was an ace back in the day but its been a while.
    VP MANUAL S/C 3.8 UTE
    Nov 2006
    Country Vic
    That is a nice little neat program you got there(Y)
    lets hope you get a bit bored again
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Quote Originally Posted by ek wagon supercharged View Post
    LOL!! Tell me what you want and ill whip something up.
    Nov 2006
    Country Vic
    Where do I start
    Maybe something 6ft tall and blonde that could be pretty nice, actually the more I think about it the more that I could ask for but I am not greedy
    just kidding
    Just little programs like that are so handy to have and it is really cool to see people just making them and letting others use them
    I am just starting to play around with the whole memcal tunning process and just little tools like this are great
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Dont spose you could make a program to input cam specs and it tell you the overlap, and how much boost you would be losing if its forced induction
    Because that could come in handy
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Quote Originally Posted by 1991_Vn2nV View Post
    As long as I can find a formula for it I can.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    nice work there airstrike, did u take into account that you really don't wanna run injectors much over 90% duty cycle
    Body by Holden, Soul by Brock
    the Legend will live forever
    PaRaDoX's Avatar
    PaRaDoX is online now boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    heh, not bad but you should put in another table for the first calculation for cyclinders to calculate total HP for all the injectors
    also thought about a kinjflow calculator?(kinjflow is the injector flow rate, when you fit bigger injectors you need to reduce this factor so you dont flood the engine) kalmaker have a table for the formula i think or you could go off the stock injector rates and use that as a basis something like my formula, ie
    assuming stock injectors are 176cc on a V6 (v8 is probbly diffrent)
    please check them i know there somewhere round that
    now stock kinjflow for the stock injectors is 0.13 grams
    soo the effective formula would be
    X= Injector Size in CC
    Y= Multplication factor
    X/176 = Y, 0.13 / Y = Kinjflow
    now lets put that to use (my injector flow rate)
    570cc/176cc = 3.2386, 0.13 / 3.2386 = 0.0401 Kinjflow
    im not too sure about working it out for 2 bar, they're might be some aditional formuala's required
    you could also use the LB/H rating on the injectors such as
    55lb/17lb = 3.2386, 0.13 / 3.2386 = 0.0401 Kinjflow
    i could be completely wrong but it should be close if im wrong someone please correct me
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Quote Originally Posted by immortality View Post
    All calculations are based on a 80% duty cycle.
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Quote Originally Posted by PaRaDoX616 View Post
    If its correct then ill add it mate. Is the Kinjflow a constant on all cars or as I would assume different. The code is the easy/quick part, the making it pretty takes time
    vt1538's Avatar
    vt1538 is offline 455rwhp LS3
    VY SS S2 11.284@125mph
    Sep 2005
    The Dead Centre
    I have an excel spreadsheet that calculates injector size from RPM, VE, Boost
    pressure, engine size etc if you want to take a look at it Airstrike. You may be able to add bits to yours to make it a bit more multipurpose. If you want it PM me your email addy.
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    PaRaDoX616 - Is that formula correct?
  15. #15
    Nov 2006
    Country Vic
    Ok from memory this is how i worked out my flow rate
    I used the stock value of the vn which is 0.14 and they are 19/lb injectors
    So how i worked it out was
    The difference your 55lb injectors are to the 19 lb injectors is 2.894 times
    Then use the old kinjflow value of 0.14 and divide it by 2.894 giving you a total of 0.048375
    Then multiply that by 1000 to get your new kinjflow value in mGrams/Sec
    48.36 mGrams/Sec
    This is the formula i gave to PaRaDoX616 and is the formula that i use and works fine so if we are saying the same thing then it does work
  16. #16
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    heh airstrike its partially correct ill update it abit as ive been corrected on some of the values
    KINJFLOW is a constant i believe
    remember most KINJFLOW values are read in grams, not mGrams/sec only redefined definitions are read in mGrams you can change the decimal places in tuner pro
    X= Injector Size in LB
    X / 19 = Y, 0.14 / Y = Kinjflow in Grams/second
    that is the correct formula for 1 bar tuning so go on and add it
  17. #17
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    remember most KINJFLOW values are read in grams, not mGrams/sec only redefined definitions are read in mGrams for greater accuracy when retuning
    Cheers mate, ill add it tomorrow.
  18. #18
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    Just tested on stockys car,
    worked out the kinjflow
    (this is for ANYONE with cream top injectors btw, they flow at 21lb/h)
    21 / 19 = 1.1052
    0.14 / 1.1052 = 0.1266
    his kinjflow should have been 0.1266
    changed it to that (effective) and it runs better with no stallage anymore :P
    my formula is very close, i think the only thing that isnt spot on is the stock injector flow rate...
    does anyone know the EXACT flowrate of stock injectors, somehow i dont think 19lb/h is right i think its closer to 17/18...
    anyway tested and it works... its very close..airstike hurry up and add it to the program!
  19. #19
    Nov 2006
    Country Vic
    0 280 150 901 's flow 18.55 lbs/hr from a spreadsheet i have laying around here
    think most people just round it up to 19 pound
    Quote Originally Posted by HoZy View Post
    Please insert your keys into your rectum an sell the car for scrap...
    Regards
    Mathew
    Ek wagon 0-60mph 6.19 20/4/07 G-Tech so there is no cheating 1/8th mile @ mph Unknown , estimated 1/4 mile Unknown
  20. #20
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    aight that sounds good about spot on, i tuned stockys for 19lb/h and he said it was alot better yet still not perfect!
    updated formula
    X / 18.55 = Y, 0.14 / Y = Kinjflow in Grams/second
    ok so for creamtops
    21 / 18.55 = 1.1351, 0.14 / 0.1233
    so for creamtops the correct kinjflow is 0.1233
  21. #21
    Nov 2006
    Country Vic
    sorry i disagree PaRaDoX
    I think the value you should have neded up getting was 0.11
    Only because i am 99% sure the creamtops run at 24 pound and not 21 pound like you have posted
    Vn Groupa the kinjflow setting is 0.11 they work out to be 24 pound
    As listed below
    Difference the 24lb injectors have over the stock 18.55lb/hour is 1.2938 times more flow.
    So 0.14 / 1.2938 = 0.1082 Grams/Sec
    Becaue the file only reads 2 digits after the decimal place i would assume that they rounded the figure to get 0.11
    Last edited by m62vpute; 08-05-2007 at 09:04 PM. Reason: bad way of showing maths :)
    Regards
    Mathew
  22. #22
    Nov 2006
    Country Vic
    21 / 19 = 1.1052
    I think stockys car would be running a bit rich using 0.1266 try and do another 1 if you get a chance at 0.11 and i think you will notice a big difference in power
    Regards
    Mathew
  23. #23
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    we have tried it at 0.11501 and it runs LEAN, getting him to try 0.1233
    but according to him 0.1266 ran ok so it must be close
    remember hes probbly down a few psi on fuel pressure :P
  24. #24
    92 VP Calais International - RIP VR Turbo
    Jul 2005
    Echuca
    His injectors must be clogged or he's not running enough pressure, heres my calculated injector flows:
    _______________inj rate____lb______kinjflow
    red_____________0.153_____30_____0.096849
    cream___________0.175_____25.5___0.110775
    blue____________0.186_____23.4____0.117738
    std black________0.206_____19.5____0.130398
    NOTE: these injector flows suit the v6 only!
    I calculated these figures from the kalmaker website:
    http://www.kalmaker.com.au/page57.html
  1. VY Injector sizing
    By fmlycar in forum V6 Development And Modification
    Last Post: 16-11-2007, 04:54 PM
  2. Turbo sizing, t04/t3 hybride on a v6
    By cracker in forum V6 Development And Modification
    Last Post: 22-02-2007, 11:35 PM
  3. exhaust sizing for V6
    By immortality in forum V6 Development And Modification
    Last Post: 08-11-2006, 01:37 PM
  4. Wiring Sizing
    By AirStrike in forum Holden Commodore How-To's
    Last Post: 26-09-2006, 10:37 AM
  5. Sub Box Sizing??
    By aperfectcircle in forum Car Audio
    Last Post: 07-03-2006, 08:15 PM
