Results 1 to 13 of 13
Thread: rough ilde when engine hot!
    VN S2 Berlina Wagon
    Apr 2004
    Default rough ilde when engine hot!
    When I start my car say 15 minutes after I have already driven it.. (When engine is really hot) it idles really bad. It revs lower than normal and fluctuates slightly. However when cold it idles better than most VNs. Sometimes it feels like its about to stall. What do you guys think it could be? Anyone had a similar problem?
    VP Executive R-spec
    Jan 2005
    Sure have with the last couple weeks of BP premium :P, so first thing to try is a different brand of fuel than you normally use
    VN S2 Berlina Wagon
    Apr 2004
    I vary my fuel brand a fair bit and I've been having this problem for a while now so I don't think it's a fuel brand problem.
    VN S2 Berlina Wagon
    Apr 2004
    VN CALAIS/VT executive
    Sep 2005
    Quote Originally Posted by lazza44 View Post
    i'd be checking...MAP...IAC and TPS operation and circuits
    VN S2 Berlina Wagon
    Apr 2004
    So what is the MAP and how do I check it? Also how do I check the TPS. I'm not getting any fault codes....Apart from the odd code13. Could this be related to my extractor/o2 sensor problem?
    VX SS S1
    Feb 2005
    vnss
    Jan 2005
    s.e melb
    my mates vn6 had this exact problem...turned out to be a failing lead.
    when it does it again just start pulling a lead off at a time and eventually you will pull one off and the engine will run the same instead of running worse after a lead has been pulled off.
    hope that made sense lol
    vnss
    Jan 2005
    s.e melb
    oh and i forgot to mention to put the lead back on before moving on to the next one
    VN S2 Berlina Wagon
    Apr 2004
    I finally got around to checking my coil pack (vn series 2) and found that the resistance between the primary terminals of each coil is wrong. I'm getting 1.86 ohms which is out of the proper range. (0.3 - 1.5 ohms) Do you think I should replace it? The secondary resistance of the 3 coils was fine. Can you buy just the ignition control module? (the block underneath the 3 coils...i think thats what its called.)
    VN S2 Berlina Wagon
    Apr 2004
    Any advice anyone?
    Also is it meant to be between .3 - 1.5 ohms or "k" ohms. cheers
    VN S2 Berlina Wagon
    Apr 2004
    VN S2 Berlina Wagon
    Apr 2004
    I thought the car would barely run with such a wrong resistance. Does anyone have experience with this. cheers
  1. Engine running rough
    By Spindry in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-11-2006, 06:43 PM
  2. VR Engine running rough
    By DaddyCool in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-03-2006, 01:19 AM
  3. rough running engine vs series ii wagon
    By namah in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-12-2005, 07:15 PM
  4. VP V6 idling rough (when engine is warm)
    By CLE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-11-2005, 10:16 PM
  5. Rough Engine Idle
    By DUMPD_VP_CALAIS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-05-2005, 03:47 PM
