Results 1 to 7 of 7
Thread: Idle RPM
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    Default Idle RPM
    What RPM should the car be sitting on when idling? In Neutral or Park the VN sits at about 1500-2000RPM. This seems a bit high to me.
    vp ss
    Mar 2005
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    Ok, its about 1500-2000 hot and like 1000-1500 cold.... Is it possible to change the idle? I have recently cleaned the IAC perhaps this is causing it? (NB the battery gets disconnected after each use atm as the glove box is out and the light just stays on and drains the battery )
    1991_Vn2nV's Avatar
    Mar 2006
    For the globebox issue, grab some paper or something and scrunch it up and place it over the button, then use electrical tape or similar to tape it over the button so that the light stays off.
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    The SS sits on around 700-800rpm. Have you played with the idle stop screw at all?
    Selling FG G6E Turbo and buying a N/A Supra
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    Well since the car doesn't get used atm as I am working on it (interior/exterior work, engine a bit later in the year) and it stays off the road (just has to be moved occasionally) I would be leaving the battery disconnected anyway (just a habit I have developed
    Quote Originally Posted by AirStrike View Post
    Where abouts is that? Would you be able to post a picture for me?
  1. idle
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2006, 04:10 PM
  2. vp ss bad idle
    By drewboy in forum General
    Last Post: 01-11-2005, 05:58 PM
  3. Vn Idle
    By RVN 355 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-05-2005, 08:18 PM
  4. Bad idle 5.0
    By Richoss in forum General Discussion
    Last Post: 15-04-2005, 10:49 AM
  5. VP S2 Idle
    By raffie87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-01-2005, 08:25 AM
