im wrecking a vn and my mate wasnt the brake booster and master cylinder, how easy are they too take out and put back into another car does anyone know?
easy, drop the fluid in brakes, remove all connections to MC and remove, the booster is a bit more of an effort, there are like 2-4 bolts and you hav ot remove the clip holding the boster arm on the pedal box. Its fairly easy... very fiddly.
aZk.
you dont need to remove the master from the booster. just unto the braket on the front.
under the dash at the fire wall there is 2 nuts holding the booster i think there 9/16ths and remove the bin from the rod that goes into the booster off the brake pedal. then pull the whole lot out the front
Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
MY RIDES
[SIGPIC][/SIGPIC]
http://forums.justcommodores.com.au/...ad.php?t=41837
