Results 1 to 11 of 11
Thread: Cooling system improvements? S1 VN V6
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Question Cooling system improvements? S1 VN V6
    The cooling system in my S1 VN V6 has been bothering me for a while. I've got an idea of what I want but I'm not sure exactly what parts I'll need to achieve it, or if it can even be done. If anyone can help me out, please do.
    Here's what I want to end up with:
    V8 radiator - dedicated radiator, not used for trans cooling as well if possible
    transmission cooler
    twin thermo fans
    radiator cap system (more like the s2 V6 than the s1)
    Anyone got any ideas where I could start?
    Sam
    IMCRZY's Avatar
    IMCRZY is offline RESPECT!
    M6 Hazzard SV6
    Mar 2007
    Wollongong
    Is there problems with the 1 u got? Or are u goin big HP?
    I WISH MY GRASS WAS EMO SO IT WOULD CUT ITSELF
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    been having issues with random splurges of coolant from the reservoir cap, only have a cheap replacement radiator made in indonesia.. i'll be going after power in the future though, either with a sc or a 5L. Probably a 5L. I just want to boost up the cooling system so I don't have to worry about it so much.
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    before you go and change anything make sure your waterpump and thermostat are up to scratch. i wouldnt worry about a v8 radiator, just get a newie and theres not much point using it as a dedicated radiator because they are 2 separate tanks inside the radiator, just run the transmission lines through the radaitor then into an external cooler, that way your providing extra cooling for the trans aswell.
    now upgrading to the series 2 would be a definate, its a far better setup than the s1's so just do that and then add twin thermo's only if you need it. i got the s1.5 (essentially the s1 setup with an added overflow) which still works very well. gets up to just below half the gauge in traffic and as soon as the thermo fan kicks it doesnt get any hotter than that.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    What do I need to change it all over to s2? I'll do that first, but I still want a bigger radiator than the cheap indonesian-made one repco sold me. the one it replaced was bigger.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    just the radiator and overflow hoses and bottle, just go to a wrecker and have a look at a s2 setup, shouldnt be too hard to suss out.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    are the v8 radiators different? what about manual radiators? could i use one from an auto v8?
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Dont stress about the V8 radiator... get an aluminium V6 newie(SII) and the SII overflow bottle, Run a dedicated transcooler and also the twin themors and you should be fine.
    I have a transcooler for sale if your interested, $70.
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    5sp VN Executive1988, VX SS 6sp
    Apr 2006
    canberra
    I thought the VN cooling systems are good. My VN temp gauge hardly moves. If i sit at the traffic lights on a hot day it might go up a little, but as soon as i start driving again it goes back down.
    Australia. Love it or leave it
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    yeah they're good, I just want it to be better. If I can improve on what's already there, I'm happy
  1. V6 Cooling System
    By tja_bot in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-03-2007, 01:27 PM
  2. help with cooling system
    By Friction in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-04-2006, 07:50 PM
  3. VT Cooling System
    By MySV6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-05-2005, 04:11 PM
  4. Oil in the cooling system?
    By portercg in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-12-2004, 11:43 PM
