Hi,
I need to take out my rear 6" speakers in my VN, but I have no tool what so ever small enuf to get to the last screw, how the hell did you guys do it?
There is the smallest gap between the screw and the window, is there nethign i can buy to get em out or what :S
Thanks in advance
91 VN Exec - Soon to have a "MyRide" thread.
WTB: Phoenix/Cardinal Red Spoiler to Suit VN(or white)
WTB: Vn Boss Kit
Take a look and support Ides of March @ www.myspace.com/idesofmarchau (brothers band - metal)![]()
If you found my post helpful, click the scales
i used the phillips head bit you can stick in screw drivers, the really small tip you can change, and then used a shifter.
then use a shifter to turn it
or u can get attatchments for socket sets witch allows u to use the screwdriver heads as mentioned above
wrecking VL COMMODORE 5 speed
FOR SALE : supra 5 speed box suite holden v8 $800
them tips will fit in a socket. had to do it once to remove a screw from my motorbike engine
Cool, my mums BF is bringing socket set over 2morrow night. Does the set generally come with the piece to put the phillips heads and stuff in?
WTB: Vn Boss Kit
you can also buy a 90degree screw driver which shoul do the job at any auto store
