Page 1 of 2 12 LastLast
Results 1 to 25 of 42
Thread: somethings not right
    2004 Black Vz R8 HSV Clubsport 297kw Gen IV M6
    Apr 2006
    South australia , Adelaide
    Default somethings not right
    back again guys, this morning after getting my bonnet open finally and putting the battery on i went to start my car and it fires up then instantly turns off (stalls), its like its firing but its un able to stay running? any one gotany idea's?? my dad suggested the fuel pump but my bro said he could hear it pumping.
    =Brock=
    My Ride
    2004 Phantom Black Vz R8 Hsv Clubsport 297kw 6L Gen IV M6-6 speed, Full black leather -
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    haha that happened to me yesterday, cant figure it out, it isnt my comp, coilpack, fuel reg, or map sensor. when u apply a bit of accerator it stays firing? but super rough and ****ty?
    Apr 2006
    mine turns on then straight away before i can do anything shuts down so sick of these old cars but i love the look of em.
    =Brock=
    My Ride
    Set of thongs
    Dec 2005
    Stonedville
    Apr 2006
    yea same one fing! problem after another, cant wait to hit 18 ..loan baby
    =Brock=
    My Ride
    Set of thongs
    Dec 2005
    Stonedville
    hehe yer, was goin good and was gonna get it on the road this easter, but now i cant drive it down the drive way like this, maybe its my crank angle sensor
    Apr 2006
    na mine played up before im pretty sure its not the CAS. the CAS never used tot urn off as soon as the car started
    =Brock=
    My Ride
    VN CALAIS/VT executive
    Sep 2005
    Quote Originally Posted by [VP2NV] View Post
    if your wanting a loan for a later model holden....wouldn't bother,parts are more expensive,and actually break down more than a VN ...VN was a vehicle that GMH had no real idea of, with the buick motor in it, it's potential
    Sep 2005
    check ECU wiring loom and connectors,after checking fuel pressure,if it's firing it's obviously getting spark,so next step is to check that it's getting fuel(enough of it)
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Apr 2006
    Quote Originally Posted by pow3rslave View Post
    are all the leads connected and on the right plugs?
    i havent played around with anything or touched anything so everything should be in the correct place. but i did notice ever since i removed the bellmouth my fuel has been going down like crazy. Im buying a new alternator on wednesday so thats one problem fixed, but i highly doubt the alternator is causing it to fire then stall on start up.
    =Brock=
    My Ride
    Apr 2006
    i also have 1/4 of a tank of petrol which is more then enough to start the car.
    =Brock=
    My Ride
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    haveyou checked the fuel pressure? have you pulled a plug to see what they look like? a mate had a car that was runnign like crap, drank fuel by the gallon and i think it stalled a lot too, got so bad it wouldn't run etc. i nthe end all they did was adjust the fuel damper and that fixed it......after the y pulled the top half of the engine apart, ignition, wiring, leads etc etc etc
    Body by Holden, Soul by Brock
    the Legend will live forever
    Apr 2006
    Quote Originally Posted by immortality View Post
    how do i do this? i recently just got a service so they replaced the old fuel filter with a new one, so that's one thing eliminated, electrical eliminated..
    =Brock=
    My Ride
  15. #15
    Apr 2006
    could it be that my fuel lines are blocked or something :S, just giving out idea's?
    =Brock=
    My Ride
  16. #16
    Apr 2006
    *bump**bump*
    =Brock=
    My Ride
  17. #17
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Have you got constant fuel pressure? The pump maybe priming it all up and then stopping.
    and 3 Dangerous non ABS VN's
  18. #18
    Apr 2006
    wll when my bro said he herd it primering he said he couldnt hear it very well. i used to be able to hear it myself without needing any oen to listen, bu i dont wanna buy a new fuel pump if its not the fuel pump thats wrong.
    =Brock=
    My Ride
  19. #19
    88GreenVN's Avatar
    Jun 2006
    Easy test. When you turn the key to the on position it will buzz away to pressurise the fuel system. Some people give the fuel tank a good old thump - but that can work once or kill the pump completely.
  20. #20
    Apr 2006
    hmm well here's what happens turn the key till the cluster lights come on, u hear it winding over, switch the car on it fires up like normal then straight away stalls. sorry i cant give much more info not the msartest of car owners
    =Brock=
    My Ride
  21. #21
    88GreenVN's Avatar
    Jun 2006
    Hmmm odd one u got there. Theres not much that will let the car start and then die like that. You could try a mates ECU in your car. I think you said the fuel filter was changed. What else was looked at during the service?
  22. #22
    Apr 2006
    they looked the whole car over but didnt say anything was wrong with any of the fuel.
    =Brock=
    My Ride
  23. #23
    Apr 2006
    its wierd cause i drove it home, had problems with the alternator, the car sat their over night and i went to start it and this problem just happened outa the blue :S
    =Brock=
    My Ride
  24. #24
    88GreenVN's Avatar
    Jun 2006
    So they didnt fiddle with anything electrical? Basicly its fuel or spark/electrical. And with it starting the fuel system is in part half working. Sorry can be much help.
  25. #25
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    dunno if anyone's said it, but is it the immobiliser, i've heard sometimes the switch gets broken and comes into effect.
    when my immobes is on and i try to turn the car over, it starts the engine for like a sec then dies.
  1. Checking somethings looking at better fuel economy
    By mag in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-04-2007, 12:02 AM
  2. somethings wrong
    By [JUDGE] in forum Car Audio
    Last Post: 16-04-2007, 08:02 PM
  3. [melb] AUTOELECS= somethings smoking! LOL need help asap!
    By wizza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-05-2006, 12:11 PM
  4. Somethings not quite right
    By Mr. Incredible in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-09-2005, 09:24 PM
  5. HMMMMMM!? somethings fishy!!
    By The1985divo in forum Jokes/Humour
    Last Post: 13-08-2004, 03:25 AM
