My car was playing up heaps a while ago, and would cut out and when i turned the ignition on the check engine light wouldn't come on and the car wont start, but i could arc C and D out on the diagnostic link with the ignition on and the check engine light would come on and the car would start, but tonight the car wouldn't start and i couldn't get the check engine light to come on.. i think it might be the ignition control module has **** itself, but does anyone else have any ideas what would be causing this?
VP TURBO WAGON --13.04 @109mph >>>>>http://forums.justcommodores.com.au/...-vp-wagon.html
Never tell your problems to anyone...20% don't care and the other 80% are glad you have them.
- Lou Holtz
Found my reply helpfull? Share the love and click the star down the bottom
it turns over just won't fire. I checked fuses and fusible links?
- Lou Holtz
my mates car did that the other day(it would turn over but it would not fire)and when u turn the key to the reds theres was no reds and the prob ended up being fuse number 9 i think it was so we replaced that and it started 1st go.
so are you getting the reds at all or is it just the engine light thats not coming on?
"A life lived in fear is a life half lived"
yeah getting reds just no check engine light and the fuses are good, i tryed my spare ecu so its not that.
Matt
- Lou Holtz
no the spare is fine i had it pluged in to my other vp and all worked good before i pulled it out. it wasn't the ignition control module, im tring to bypass the sercuity swich in the door to see if that is the problem
- Lou Holtz
what the the ani theift do- stop spark? cause im getting spark so i don't think its that anymore, but ive given up for today so any more ideas?
- Lou Holtz
i'm not 100% sure on factory fitted anti theft,but aftermarket set ups are wired into the fuel pump line,so when you go to try and start it,you won't hear the fuel pump whirring until you dis-arm the engine immobiliser.
you talk about anti theft...is yours factory fitted? if so i wouldn't mind betting it's the lock in your glove box,they can give up the ghost just like that,has happened to me,replaced lock and away she went,got engine light back on......sorry i didn't even think of it, at first,as i have only had it happen to me once,but i have heard it can be a common occurance.
yeah factory fitted, so when your lock **** itself did your engine light stop coming on?
Matt
- Lou Holtz
yes ....because the motor was immobilised,have it checked first,(lock in glove box)in case it's not...but thats how mine went
next time ...when you get it going,you watch, on the dash, the engine light only comes on when you press the remote(on factory fitted anti-theft systems)
my lock is in the passanger door, but i don't have the remote or the key, so it is swiched off. but i have it going now, it was a wire on the bcm that wasn't conected properly from when i put a vs dash in on friday and the check engine light was the plug at the back of the cluster wasn't making contact, but i thought it was the same problem as i was having a while ago. thanks for your help and suggestion anyway.
Matt
- Lou Holtz
maybe your fuel pump get someone to turn the key to get the motor crancking and someone to bash the fuel tank under the car
it wont go if the engine light isnt on at ignition
if the EFI relay is ok try the immo switch in the pillar
