Hey team ive got a VP Commodore motor in a imported 4runner..Engine was running magic then went into Auto electrics for new wiring loom due to fuel pump staying on after car off..ran fine for a couple weeks.now it will run fine for a while then if i turn it off for 30 minutes it will start then run really rough and Backfire pretty badly..and stop..if i leave for an hour it will run fine??..i have changed...
Plugs,leads,injectors,coil pack,computer,fuses,oxygen sensor.
yesterday i found the fuel pump fuse melted into the housing so i replaced the housing with new ones i was so happy thinking i found the problem but it just did it again...
before i replaced the computer the old one was heating up so hot couldnt touch??
does anyone know what might be wrong or had similar problems...
Please look past the 4runner body the motor came out of my vp i loved very much when it got rusty i got a transplant....
Any help would be great...
Also tried pouring water on CAS when it started running bad didnt help??
if u pour water over the CAS it will start but still run ****ty might pay to geta new one as well.
=Brock=My Ride
2004 Phantom Black Vz R8 Hsv Clubsport 297kw 6L Gen IV M6-6 speed, Full black leather -
ecu getting hot, try all your earth connections etc. fuses melting is normally caused by bad connectoins causing excessive heat.
Body by Holden, Soul by Brock
the Legend will live forever
Check your fuel pressure.
