Results 1 to 9 of 9
Thread: help needed urgently RE imobilizer
    vp commodore
    Mar 2007
    Default help needed urgently RE imobilizer
    hey guys i have a 92 vp lexen / commodore and it has the button clicker for the imobilzer. the trouble is its started to play up and the key switch on the passenger side front that bypasses it has been drilled out by the last owner.
    is there any way that i can bypass the imobilizer permanently?
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    VP Lexcen commodore
    Jul 2006
    Ipswich Qld
    Matt_vp's Avatar
    Matt_vp is offline Donating Member
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    there should be a pink wire and a pink and black wire, u sould be able to join these 2 wires to bypass it and u might have to cut the orange wire.
    VP TURBO WAGON --13.04 @109mph >>>>>http://forums.justcommodores.com.au/...-vp-wagon.html
    Never tell your problems to anyone...20% don't care and the other 80% are glad you have them.
    - Lou Holtz
    Found my reply helpfull? Share the love and click the star down the bottom
    vp commodore
    Mar 2007
    Quote Originally Posted by pow3rslave View Post
    so when you say it's been drilled out, what's left?
    the only part of that that is left is the housing where the key once went in.....so is there a way i can disconnect the wires from that and join them to bypass it?
    vp commodore
    Mar 2007
    Quote Originally Posted by Matt_vp View Post
    so is that for real mate? or are ya just mucking around?
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    thats how i did mine on the weekend, there sould be 4 wires going to it, pink, pink and black, orange and a black one.
    - Lou Holtz
    vp commodore
    Mar 2007
    ok thanks mate!
    did you find these wires behind the bypass lock in the inside passenger door or elsewhere in the car?
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    u have to pull the side bit off the dash then u will be able to see where the wires come off the back of the lock, go up then into the wiring harness in the dash, there might be a bit of steel plate there aswell that u will have to drill the rivits out off to get it off so u can cut and join the wires.
    - Lou Holtz
  1. urgently needed auto - manual vs wiring diagram
    By micvs in forum Electrical Wiring / Questions
    Last Post: 14-01-2007, 07:41 PM
  2. urgently needed: black chaser rim
    By white vn ss in forum General
    Last Post: 31-12-2006, 01:31 AM
  3. How do I disable an imobilizer?
    By V8commodore_chick in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-11-2006, 05:47 PM
  4. WTB Urgently
    By hsvd_g in forum Swap / Wanted to Buy / Trade
    Last Post: 26-07-2005, 09:03 PM
  5. WTB:Urgently
    Last Post: 25-07-2005, 11:44 PM
