Results 1 to 9 of 9
Thread: remote boonet latch
    VNSS Atlas Grey
    Feb 2006
    Default remote boonet latch
    hey guys
    has anyone heard of a remote button the open the bonnet instead of the cable in VNs? it works just like your boot release.
    cheers
    VN V6 0-60mph in 7.52
    Peter Brock
    Morton's Avatar
    Fairstar the Funship
    May 2006
    I'm thinking that any such system would require a pretty powerful actuator to wind back a VN/VP bonnet hard enough to reliably pop it. I've never heard of such a kit, and I imagine it would be fairly bulky and expensive if it did exist.
    That's just me, though. I'm frequently wrong
    The 1972 HQ Kingswood
    VNSS Atlas Grey
    Feb 2006
    lol this bonnet latch was made by holden but the stopped making it because they couldn't open the bonnet after crashes. so in away it would be good but then again when your battery is flat have fun opening the bonnet.
    Peter Brock
    Morton's Avatar
    May 2006
    lol yea, you'd want some sort of over-ride. I can see flat batteries, worn alternators and blown fuses causing headaches just for a start At least when boot actuators fail (and they frequently do) you can open the damn thing with a key.
    YMY-88U's Avatar
    YMY-88U is offline Donating Member
    Project VH SL/E
    Jun 2005
    Quote Originally Posted by Morton View Post
    not mine... ive welded over the boot hole because someone decided that they would try and break into it, hopefully the electric release wont fail but it now looks heaps better... to answer the question i have never seen one before either, didnt even know that they existed...
    Morton's Avatar
    May 2006
    oh well, if all else fails you'll just have to do what I did to my old mazda after its accident: develop a manual release which can only be activated by crawling into the boot through the back seat and forcing the latch with a chisel.
    Might I note that this also had to be done to -close- the boot, as the mechanism wouldn't catch by simply lowering one onto the other... the whole rear end was off-centre. Imagine actually getting -INTO- the boot of your car every time you shut it... ...
    VN Ute
    Oct 2006
    hahaha had to do that in my laurel after a bit of sideways action...... the hole in the center of the seat wasnt big enough for me so i ripped it out and cut the hole bigger lol.... was just a drift hack so it didnt matter but wed moved the battery to the boot and had to open it quite often
    Japanese scientists have created a camera with such speed that they now can photograph a woman with her mouth shut!
    89 vn calais
    Oct 2005
    aldinga beach
    the eb falcon has a servo bonnet release as my flatmate has one on his.. although i am not 100% if its an aftremarket one.. and yes it is very hard if you have a flat battery ..
    WhiteLightning's Avatar
    WhiteLightning is offline JCCCQ Member
    VX S, 3.0iTD Rodeo
    Apr 2007
    Innisfail
    vn - vp are well known for the two person approach to opening the bonnet...as good as it sounds...why not stick with the old lever and cable
  1. Bonnet Latch
    By Cody in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-02-2012, 12:30 PM
  2. Remote engine start on VXII berlina with factory key remote
    By cougar1985 in forum Electrical Wiring / Questions
    Last Post: 02-11-2010, 01:32 PM
  3. bonnet latch replacement vn
    By steveabbott in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-11-2007, 07:22 PM
  4. Boonet Pins & Clips
    By Friction in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-04-2006, 05:01 PM
  5. Bonnet Latch
    By Gav95VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-04-2004, 08:23 PM
