Results 1 to 4 of 4
Thread: Boot light constantly on
    VX II Calais L67
    Dec 2005
    Default Boot light constantly on
    I was suffering battery drain so after a while with the multimeter I found the problem was interior illumination...checked around and for some reason my boot light was constantly on. Took it out and current draw from the battery is back to normal. Anyone know where the sensor for the light is located or if this is a common problem?
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    sensor is a switch on the passenger side of the boot, it gets tripped by the boot arm contacting it, mine did this too. turns out it got worn down or bent or something, you could probably replace it with a cheapish switch from dick smith if you know what your doing, i made one with a mercury switch.
    VX II Calais L67
    Dec 2005
    VK/SL 3.3l AUTO SED.
    Dec 2006
    Eastern Burbs Melb.
    Or you could adjust the bracket it is screwed into, so that it works the way it's supposed to.
    No it's not NOS it's LPG
    Good Rep points are always welcome
  1. boot light stays on when boot is closed
    By seans VL Calais in forum Electrical Wiring / Questions
    Last Post: 25-09-2007, 05:17 PM
  2. boot light problem?
    By padrickz88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-11-2006, 06:28 PM
  3. interior/boot light......
    By donsvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-10-2006, 08:42 PM
  4. Interior & Boot Light
    By Agro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-10-2005, 03:42 PM
  5. Boot light in a VP wagon
    By MagwynTheGrimVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-04-2005, 06:52 PM
