Hey guys i got the blower running on the vp and a 70mm TB and when i was changing the TB over i broke the plastic clip on the kickdown cable, i i did a dodgy repair on it an took it for a drive, and the the car wouldn't idle below 1500rpm(at a dead stop) so i jumped out and adjusted the idle, drove off and same happened again... i also noticed if i was cruising along then took foot off accelerator pedal it would hold the revs and just stay at the speed.
I got under the bonnet earlier today and had a look and came up with these findings:
Car not running- push on accelerator pedal TB opens and closes like normal.
Car running rev it then back off the trottle stay in the same spot, for a bit then slowly closes, but doesn't close 100%, which causes 1500 rpm idle, but if ya push the butterfly on top of tb shut it stays shut and idles fine.
We came to the conclusion that the boost was causing it to stay open, and confirmed that by running the car with out the blower running.
Any body had similar problems, or got any ideas on how to fix it?
busted ass vp
is your blowoff valve working proply, with mine as im slowing down i had to tap the accelerator pedel so the bov went off and let some pressure out..
maybe u could put a spring on the t/b butterfly.
are u running the standard pully or a smaller one.
Matt
VP TURBO WAGON --13.04 @109mph >>>>>http://forums.justcommodores.com.au/...-vp-wagon.html
Never tell your problems to anyone...20% don't care and the other 80% are glad you have them.
- Lou Holtz
Found my reply helpfull? Share the love and click the star down the bottom
I've go the bov that comes from crs(recirculates the air) dunno if it works, any ways to check? And i'm running the standard pulley, i was running vacuum off the map sensor and i moved it to the fuel pressure vac, but it's still the same.
busted ass vp
i don't know what the standard crs ones look like can u post a pic. when the car is idling at 1500rpm u should be able to hear the air being pumped out of the bov, or remove the pipe that the air gets recircluated throough and see if u can feel any air being pumped back through.
Matt
- Lou Holtz
hey 10000 fists im havin the same prob as you but i dont know what ive done wrong, i recently removed that bellmouth out of my vp, put everything back together, now i start my car and it idles higher than 1500rpm (with bellmouth out) same if im driving along it will hold the revs and stay at a continuous speed at around 50-60, if you figure out how to fix yours let us know ay
i had this problem, once i reset the ECU it went fine again..
also getting a service done helped, as they adjusted the throttle and kick down cable.
=Brock=My Ride
2004 Phantom Black Vz R8 Hsv Clubsport 297kw 6L Gen IV M6-6 speed, Full black leather -
I checked and the bov is working, so i tried a spring like mat said it works but is very dodgy and i can't get 100% throttle but i's the only way to stop it from holding its revs, i've taken the 70mm TB off an i'm going to put on the standard one, cause it was fine with that on...
EDIT: i might try reseting the ecu then i didn't even think of that... let yas know how i go with it all.
busted ass vp
id definately reset your ECU and IAC. with the TB open the same angle as the v6 one when idling, youre letting in a lot more air, especially with the blower.
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
How do i reset the iac?
busted ass vp
turn it on, rev to 3000 for 10 seconds or something. or remove engine fuse for 30 seconds. not quite sure
does anyone know exactly how to reset the ecu and iac??? cause ive tried reving my car at 3000rpm for 10-20-30 seconds still did nothing. I have not tried to remove the engine fuse though.
discounect your battery for a couple mins, put it back on then rev ur car to 3000 revs for about 20 seconds, youll know its working cause youll hear it going up and down through the revs'...itll go higher and lower reving..
=Brock=My Ride
alright sweet as il give it a go now
wheres that located, fusebox in the engine bay or under the steering wheel?
ah dont worry found it
nah it doesnt work, doesnt go up n down through the revs either.. i think il just get it checked out by a mechanic
I still haven't had a chance to try it out yet, i'll go out after tea and see how i go, i'll keep you posted.
busted ass vp
Hey guys.I had the same problem with my car when i out a 70mm tb on. It idles at like 1500 upwards. I found that quickly tapping the accelerator with my foot at idle would make it return down to its normal idle. Im not sure whether it was because the spring was new and was tight or something else..but it works.
hey i just put that bellmouth back into my car, now it idiles fine, but if i go from drive to park it will basically stall?? as in thers no air or sumthn gettin into the engine
r u certain all the bolts were done up tight and gaskets getting a go seal, because when i removed the bellmouth i just reset the ecu and iac and all was good and i have help a few mates do theres aswell without any problems.
Matt
- Lou Holtz
- Lou Holtz
