Results 1 to 6 of 6
Thread: ignition troubles with 90" vn exec
    Jul 2005
    Default ignition troubles with 90" vn exec
    hey, i have always had trouble with the ignition since the previous owner ripped the imobiliser out (normally takes 1 or 2 starts on some occasions). Today it has gotten worse, whenever i have the car on and then turn it off it takes about 1 - 3 hours to actully start again. it is turning over and everythings working but not starting. if anyone can help i would be greatful, if it aint the imobiliser does anyone know what else it could be and how to fix it since i really dont have money spare for a while and need my car thanks
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Do you know how to check the error codes? Checking your Computer for Faults (VN - VP) Its a classic symptom of the crank angle sensor. I don't think it would have anything to do with removing an immobiliser.
    Jul 2005
    thanks its the CAS, anyone know if i can fix it by hand and what i have to do if i can or if i cant can someone give me a clue howmuch it would cost to fix thanks
    VP Executive S2
    Jul 2005
    I have the same problem at the moment. Though when my car starts it sometimes backfires and just dies while i am driving it. I am pretty sure its the Crank Angle Sensor since the ecu is saying its that but does the crank angle sensor cause it to backfire and die when driving cause i am thinking its more of a serious problem. It has only been doing it since the Crank Angle Sensor has gone, can anyone say for sure it is just the crank angle sensor or would it be something else aswell thanks
    92 vp commy
    Dec 2011
    Yer I just replaced mine u need a claw clamp to pull the harmonic balancer off cost about $ 50 for tht an $60 for the CAS
    vp calais, vn calais, vp berlina all 3.8 litre
    Aug 2008
    Pascoe Vale South, MEL
    change the balancer and the sensor together (new ones) theyre a wear and tear item like plugs and leads, but less frequent...
    dont sweat the petty... pet the sweaty...
  1. VS ignition troubles
    By SSGEN-3 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-10-2008, 12:12 AM
  2. ""need help"" own a stocko 3800 vp and wanting to really give it some horsepower
    By boourns in forum V6 Development And Modification
    Last Post: 19-07-2008, 06:59 PM
  3. VP injectors opening when ignition "ON"
    By V85000i in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-03-2007, 08:08 PM
  4. "94" Vr Exec
    By MJR_VR in forum VR - VS
    Last Post: 26-05-2006, 11:59 AM
  5. ignition troubles
    By Hinchman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2005, 06:36 AM
