Results 1 to 5 of 5
Thread: Are series 1 & 2 engines interchangeable?
    Tadeusz Guest
    Default Are series 1 & 2 engines interchangeable?
    Hi,
    I've got a VN series 1 v6 in a Hilux. The engines about to die, so I was wondering if I can put a series 2 VP motor in without changing any of the wiring & computer.
    I know I'll have to change the radiator hoses, but will everything else bolt straight up.
    Thanks,
    Scott
    OSL-060's Avatar
    OSL-060 is offline Banned
    Dec 2003
    SE QLD
    It should be fine Scott in the wiring dept. Maybe a slightly longer coolant temp sensor wire if anything. Can't think of much more off the top of my head. All minor thou.
    Computer wise they're the same with the exception of the memcal.The series II had a revised memcal to suit the subdued cam profile and some other minor running changes.
    Your old comp/ecu will run the SII but I'd grab a SII memcal and slot it in just to lower the NVH (Noise Volume Harshness) and better match the cam. This and relocating the bitch of a rear hose were the only reasons Holden made the update.
    Garth's Avatar
    Garth is offline Your guess is as good as mine......
    tj jeep wrangler 2 dr, 4ltr 4 inch lift, yada yada
    Space Invaders Champion!
    Oct 2002
    good luck champ
    yes, wiring looms for engine are the same, you will have o2 sensor issues, vns2 uses a 2 wire one, vns1 uses a 1 wire one, that is the only problem, the vn s1 looms for inside, arent the same, you wont make them work, pretty sad, but engine loom's yeah, they are the same
    i am the god of britany spears womanizer on just dance on the wii
    OSL-060's Avatar
    Dec 2003
    SE QLD
    Are you 100% sure Garth? Can't you just retain the series 1 headers and o2?
    I had a SII ECU in my old S1 for about 2 months and it run the vehicle fine through the S1 loom. On top of that allmost every S1 I've seen that's had an exhange motor fitted got the SII.
    I'm not saying your wrong just interested.
    Tadeusz Guest
    Default Flywheel & starter
    Thanks for the info,
    I've got the S1 motor out now so I just need to find someone open so I can get an exchange motor.
    One more issue. I'm using a manual gearbox. Will my S1 flywheel fit onto a S2 motor, or do I need a S2 flywheel? If my S1 flywheel works, can I put it on a motor setup for an auto, or is there more to it than just adding a flywheel?
    Also, will my S1 starter motor work with the S2 motor?
    Thanks,
    Scott
  1. VT and VX panels interchangeable?
    By TGibson in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-09-2007, 09:24 AM
  2. interchangeable parts
    By mrbeef in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2007, 09:19 PM
  3. Vt Series 1 & Vs 5litre Engines
    By EX_FORD_BOY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-04-2004, 11:22 AM
  4. Series 1 & 2 Engines
    By adsVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2004, 09:10 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
