Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Thread: Oil for V8
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Arrow Oil for V8
    Hey all,
    I just recently purchased my new pride and joy from a member of this forum, Reaper. The car is a HSV VP GTS and I wanted to know your thoughts on the oil I should give her. Is there really any difference between oil for V8's and V6's, I just want the best protection I can get.
    Thanks,
    Mack.
    pandaman's Avatar
    pandaman is offline Aussie Muscle Fan
    VN Berlina 5.0 A4
    Feb 2006
    Quote Originally Posted by Mack View Post
    Hey all,
    Thanks,
    Mack.
    Holden specify 20W50 for the 5L. I personally use castrol GTX2 and change it every 5000km. Different people will give you a multitude of different opinions.
    Beau Duke: Man, I'm never gonna get outta this car again. I'm gonna live in it, I'm gonna eat in it and I'm gonna make sweet love to it!
    Luke Duke: You mean you're gonna make sweet love IN it.
    Beau Duke: Oh no, I'm gonna have sex with it.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    As long as you use the oil recommended for the engine it should be good. If Reaper has been using synthetic oil, find out what it was and keep using the same stuff. If you change back to mineral oil after using synthetic it's not good for the engine.
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    id sugest valvoline formula 5000. its what i use. its 15w/40 and ive had no troubbes using it,
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    VP Executive R-spec
    Jan 2005
    I thought original spec oil was 15-40? anyway I run 10-40 Synthetic at the moment might be a little thin but I'm one of these people that think if the engines still tight enough to not burn oil then use the thin stuff , but for such a machine as a GTS I think Penzoil 15-50 synthetic if there is such a thing would be ideal. I'm not a believer in mineral oil
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    Quote Originally Posted by greenfoam View Post
    that is pritty thin for an old vp ! you dont belive in it?
    vn executives
    Sep 2005
    I have been using Castrol Gas 15/40 for two years and now changed to Penrite gas10 which is bit thinner 10/50 and semi sythetic, is there any problem? some time I found the engine is nto stable when I idling.whatr about if I change back to castrol which is a mineral?
    kellyvk's Avatar
    kellyvk is offline kellyvk
    vk calais 5L/ vk commodore 6
    Apr 2007
    sydney
    Quote Originally Posted by andyli View Post
    no good chopping and changing too much.
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Well I just found out the Reaper was using Caltex Haveline multigrade (20-50). He seems to think it was semi-synthetic. I'll double check today.
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Go the SIN 15 OIL From Penrite
    www.penrite.com.au
    Sin Engine Oil 15 is a fully synthetic oil blended with highly shear stable viscosity modifiers and man made base oils. It exceeds API SM/CF and ACEA A3/B4 and JASO MA.
    This oil is good for Turbo Engines,Supercharged and Engine's to the capacity V12
    Cheers.
    * RVN 355 *
    jamo25 is offline VPSS
    VPSS
    Nov 2005
    mate. use Bp coarse plus. a very good oil that isnt expensive. i no of many people with tuff motors using it. i use it my self... and its 20w-60
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    GRAVE DIG, lol.
    This weekend I'm doing the whole service. I got some Pennzoil Synthetic 15w-50 Oil, see how that goes yeah.
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    When switching from mineral to synthetic it is a good idea to run a flushing oil through the engine first. If you don't the synthetic oil has a tendancy to dislodge any sludge build up and then it starts blocking things up. A flushing oil is designed to dissolve the build up and flush it out.
  15. #15
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    flushing oil you say, and how much would this flushing oil cost my kind sir? Its costly buying parts for a service, just got fuel filter, oil filter, oil, leads, plugs, dizzy rotor, dizzy cap.
  16. #16
    vn 5ltr + bt1 pack
    Dec 2005
    YOUNG N.S.W.
    Its only about 12 bucks for oil flush from repco but i've herd that 200-300 ml of diesel will do the same thing.
    I didn't do it
  17. #17
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    diesel is the last thing you want inside of your engine.
    mack you forgot the air filter....
    MY RIDES
    [SIGPIC][/SIGPIC]
  18. #18
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by xcop5l View Post
    No diesel is coming near my engine.
    Yeah, the air filter was $16 or something, I had an old OK one from my VN sitting in my cupboard after installing my K&N POD. I wish I bought a K&N Panel now so I can reuse it on the GTS. So I changed from the one that was in the GTS (really dirty) to my other one which I cleaned with vacuum cleaner.
  19. #19
    flyen is offline bye bye
    Feb 2006
    Quote Originally Posted by RVN 355 View Post
    www.penrite.com.au
    cheers for the link'
    i'll try Penrite HPR 10 and see how that goes
    before you reply ya suppose to use HPR15, i have a VS engine in my VN
  20. #20
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Never use diesel in an engine, all it will do is thin the oil, not flush it out. You can use diesel oil however, something like a 10w40 for around 100-200kms, the extra detergents in there will act like a flush. Diesel oil is more expensive than petrol oil so a flushing oil may be cheaper. Around $30 for 5 litres I think.
  21. #21
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Quote Originally Posted by flyen_vn View Post
    What difference does that make? A VN S1 through to VS SII is all the same mate. 10 weigh is far to thin, will be tappet noise like no tommorrow!
    Selling FG G6E Turbo and buying a N/A Supra
  22. #22
    Feb 2006
    Quote Originally Posted by AirStrike View Post
    thats what the site reccomends for a VS 5.0, 95 to 98
  23. #23
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
  24. #24
    Holden Cruze CDX
    Jul 2006
    Miranda
    from memory i am using 10-50 in my 5.0l works fine no noise or anythign ... although i have noticed tha ti don't get as much oil pressure on idle .. i have reason to believe that it maybe a lil thing for the oil pump to suck it up so i might try a 20-50
    My mechanic also reckons 20-50 would be better...
  25. #25
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Well I rang the oil bloke and he either said go a 20W-50 mineral or a 15W-50 synthetic. Ive herd good thing from synthetic, so I chose the 15W-50 fully synthetic blend.
