Results 1 to 9 of 9
Thread: shudder from left rear wheel
    georgeonboost's Avatar
    georgeonboost is offline clutch it!
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    Default shudder from left rear wheel
    hi guys, when i turn left hard i get a real bad shudder/rubbing/grinding noise from the left rear wheel but when i turn right hard i don't :S any1 know what might be wrong? could it be a fcuked diff? its in a VP V6 executive, non-irs. if it is the centre i have to replace, how much is a LSD?
    -George
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    when you get a chance jack up the left rear and have a look to see if theres rub marks
    if there is id say your panhard rod bushed are shaged or you have a bent axel
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    dont think its a bent axle. the car is sitting on super lows so it may well be the panhard rod. ill have a look tho. thanx
    -George
    J_D
    J_D is offline
    VN S1 and VS V8 Statesman
    Jul 2006
    Ipswich. QLD
    you probably need an adjustable panhard rod to re-centre the diff. My LHR wheel used to rub when turning corners if anyone was in the back seat and now ive got an adjustable panhard rod it doesnt.
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    yea well there you go...might have to get an adjustable panhard rod. ill keep you guys posted. power steering fluid is pissing out all over the joint onto my exhaust and burning making smoke. pump is rooted i think. already got a new rack about 4 months ago.
    -George
    VN CALAIS/VT executive
    Sep 2005
    Quote Originally Posted by georgeonboost View Post
    -George
    try what J-D has suggested,also looking at all the rear end bushes,i'm just wondering if it's a wheel bearing (just about to go)when you turn and put the weight on that side?
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    thing is its when i turn left therefore im putting weight on the right side. i dunno...still gotta check all the bushes n stuff out still
    -George
    Sep 2005
    -George
    have a look at your top arm bushes...i know they make weird noises when they are shot
    Garth's Avatar
    Garth is offline Your guess is as good as mine......
    not telling
    Space Invaders Champion!
    Oct 2002
    my vn did the exact same thing. with me it turned out the shock absorber it'self was rattered. as a result, i replaced shockies front and back, all was good there.
    look for rub marks, and look for peices of shiney clean metal, if it's clean then soemthing use to be sitting there and chances are it should be there. i.e
    lower radius arm bushes. if they fall out, you see a peice of clean metal.
    i am the god of britany spears womanizer on just dance on the wii
  1. Front Wheel Wobble Car Shudder Help
    By jolea682 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-11-2006, 10:17 AM
  2. Shudder from rear
    By holster in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-06-2006, 04:01 PM
  3. Help, wheel shudder!!
    By Hytes in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-02-2006, 12:01 PM
  4. 1 f****d left wheel suspentions and what eva
    By damo15 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-08-2005, 12:52 AM
  5. Left wheel spin in a single wheeler
    By AVPTOC in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2004, 08:48 AM
