Results 1 to 9 of 9
Thread: Ls1/2 Into A Vn/vp?
    Apr 2005
    Default Ls1/2 Into A Vn/vp?
    Just wondering whats involved in fitting the LS1 or LS2/ 6 speed into a VN/VP?
    Is there any mechanical engineer that does mounts, etc, and the bottom line...
    Is it worth the headaches?
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    10k fully in including everything & engineered... For 220+ rwkw & possibility to shoot it up to 300rwkw for minimum value n/a...
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    In short, HELL YEA!
    The 1972 HQ Kingswood
    Apr 2005
    Priced a 6 litre crate engine for 7400 which sounds pretty good, no starter, exhaust, ancilliaries, but for 4500 can get a 100 k 5.7 with all ancilliaries, comp and loom. If I went T350/400, how hard to remove the trans programming?(Or does it need removing at all?)
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Quote Originally Posted by NOGEN 3 View Post
    Keep in mind things like the starter, headers, etc are no good to you.
    Selling FG G6E Turbo and buying a N/A Supra
    Apr 2005
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    castle mania do that or rod shop one of them. some company sells engine mounts n all the stuff to get it working.
    13.3 1/4 exhaust only untuned!
    Doctor Sodways's Avatar
    Doctor Sodways is offline Legendary Baby!
    Slammed VeeDub Rat and a Brunette...
    Sep 2005
    Behind a Camera...
    Castlemain rod shop is the one your thinking of i think
    I used to play sports. Then I realized you can buy trophies. Now I’m good at everything.
    The best car safety device is a rear-view mirror with a cop in it. ~ Dudley Moore.
    Apr 2005
    Castlemaine Rod Shop. Yeah, I think thats what you meant didn't you?....
    Gotta give them a call and find out how much for the full kit which apparently comes with starter, engine mounts, trans mount and extractors to suit LS1 to VN/P.
    Thinking of putting a T350/400 behind it to save some cash/spend more on building up a stronger trans/ small stall, rather then spending the same for a standard 700....
