i um just killed my vn, the radiator, condenser and all the front is damaged. radiator support panel is ###ked up bad, i was planning to put a vs front on the vn, obviously i need a new radiator support panel to suit a vs. if anyone has some knowlage of panel beating id like to no if i can sorta just cut and weld one??if anyone knows there vn's and vs' please point out the major differences in the front end thanks!
Don't blame me, It's that damn percadan..
If you ask me, that stuff rots your brain...
And now a word from our new sponsor.. Percadan? oh crap!
talk to VN2NV, he's done it. its in his my ride thred, it seems pretty easy to do as well.
=Brock=My Ride
2004 Phantom Black Vz R8 Hsv Clubsport 297kw 6L Gen IV M6-6 speed, Full black leather -
hasnt he got vN lights still?
No need to put in VR/VS support panel as the VR front will bolt straight on.
to the vn one? isnt it completely different? the driving lens surrounds are different? isnt the bumper bar support entirely different aswell? needs a new one ne way, mines pulled back into the engine
Ive seen a VN wag with a vr statesman front on it(un cut)This was at a panel shop and he had sold the front and was stripping the car.
The only difference on the radiator support panel is a section on the ends... On the VN's its square and on the VS its more rounded.
I have a full VS front end... Bonnet, headlights, guards, front bumper and reo bar. Quote from my ride:
"Fitting the guards is fairly simple, just you have to cut the radiator support. On the VN's, the radiator support is sqaured off where as the VS is angled on the end... I copied how it is on my VS and cut it like that, so heres a before and after pic of where I cut the radiator support on the Passenger Side of the vehicle:
ahhh i see.. so its just making the support rounder to accomadate the more rounded front guards? here i am thinking its a different support all together.. um with the front bumper support, is it the same as the vn one or flatter to fit a vs bar? if u can tell me besides the obviose what i need to fit the front guards, lights and bar? u have any new pics? i cbf searching cheers brudda
The VS reo bar which is the front bumper support is different yes. That needs to be replaced. Guards are needed and you have to cut like I did in the pics, headlights and indicators.... One of the brackets needs to be cut here as welll otherwise the headlights wont fit on... And as for the bonnet you also need the hinges and the hose for the washer jets runs on the opposite side on a VS, so you will need to remove ur firewall cover and run your hose down the other side and perhaps add more so it reaches the hoses in the bonnet![]()
so the bar support will just bolt on where the other one does? i need a new radiator support panel anyway, mines too far gone to reserect.. the plastic bar guides on the side are the same?
Found Ur Thread Thanks Man!
