Results 1 to 8 of 8
Thread: What did i do wrong?
    adam69 is offline Banned
    VT Clubby
    Oct 2004
    Default What did i do wrong?
    I have been swappig clusters in my VQ and when i put it back in two of the LED screens do not light up.I can see the numbers but they are not backlit.How do i fix?
    VN CALAIS/VT executive
    Sep 2005
    Quote Originally Posted by adam69 View Post
    now i haven't pulled one out and had a good look,do they have bulbs?(silly question i know) could it be the circuit board causing your problem?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by samuels View Post
    The trip computer has 4 globes in it. Take the 3 screws out and flip the white pannel with the LCD's in it over. You have 4 black plastic globe holders that twist out with a flat blade screw driver. Your cluster that worked ok will have 4 good globes in it. Holdens charge about $16.00 each. Jcar sells the globe bit only for about $2.00 each.
    If your original trip computer globes worked just swap them over and be a bit gental as the globes can stop working with the smallest of bumps.
    and 3 Dangerous non ABS VN's
    VT Clubby
    Oct 2004
    Quote Originally Posted by 88GreenVN View Post
    I havnt swapped anything over yet,it happened when i was first swapping clusters.All i did was remove my cluster,fit the other,remove that and refit the original.
    88GreenVN's Avatar
    Jun 2006
    OK the globes in the "other" cluster are dead. Or when you put your cluster back in and now the trip computer is dark - no lights.
    Take cluster out and re fit.
    VT Clubby
    Oct 2004
    Basicly removed my cluster,fitted the other then refitted my and had the light prob.
    91 VP com
    Jul 2006
    what he's sayin is take the globes from you old cluster and put in the new one see if that fixes it..
    busted ass vp
    88GreenVN's Avatar
    Jun 2006
    I'd guess that there is a plug not making good contact or the new cluster did not like its new home and fried something.
  1. WTF is wrong with my CAR !!!!!!!
    By Joey_21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-03-2007, 11:48 AM
  2. There is something seriously wrong
    By vn2nv in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-03-2007, 01:51 PM
  3. what is wrong?
    By kowan in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-02-2007, 06:40 PM
  4. something wrong???? HELP
    By potshots007 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-10-2005, 09:46 PM
  5. where did I go wrong ?
    By Spin in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-01-2005, 02:34 AM
