Results 1 to 16 of 16
Thread: Shift Kits - Stage 2 vs 3
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    Default Shift Kits - Stage 2 vs 3
    Whats involved in a stage 2 and 3 kit? What are the differences? (And is there such a thing as a stage 1? Just curious lol)
    What are the benefits etc of 2 and 3 stages?
    Thanks
    beefcream's Avatar
    beefcream is offline Lethal LOKKA
    VS SS 5speed (project) VN exec v6 (daily)
    Sep 2005
    South,Adelaide
    stage one doesnt do much.. just strengthens the shifts a little bit. stage 2 gives u real hard shifts so it chirps from 1st to second. and stage 3 is full manuel shifting
    VS SS - Street/Show Project [BEEFY]
    http://forums.justcommodores.com.au/...-beefy-v2.html
    HID Kits from $100 - Installation available PM FOR DETAILS
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    As beefcream said...
    Stage 2 and 3 are exactly the same... You buy the transgo kit and it is for Stage 2 and 3... The only difference is stage 3 is fullly manualised and stage 2 will just hold the gears like a manual but D is still automatic shifts (stage 3 means D is either 3rd or 4th only).
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    So with a stage 2 kit if you set it in 2 it wont shift back to 1 but if you set it to 3 it will shift up and down as much as it wants?
    Mar 2006
    no stage 2 will shift fully automatic.. just hard shifts.. stage 3 is fully manualised where u have to change gears with the lever.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Stage 2 will NOT change your car's shifting pattern at all. I'm not sure if a stage 2 kit implies corvette servos, but if not, I would highly recommend them. Larger, and much stronger than the original numbers.
    Stage 3 = Stage 2 + manualised. i.e. if you're in 3rd gear doing 60kph and you boot it, the car will NOT shift down to 2nd.
    The 1972 HQ Kingswood
    1991_Vn2nV's Avatar
    Mar 2006
    What I got with my shift kit from Transgo:
    Transgo Stage 2: Will not shift above the gear selected with the shift lever. Will downshift to any gear, at any speed with the selector lever. High throttle 3 - 4 shift delay is controlled with the lever.
    Transgo Stage 3: Trans will start off in what ever gear the selector lever is in. Will shift to any gear ratio selected, at any speed, by moving the lever.
    The kit is the same (i.e. you buy the same kit for stage 2 or 3) but the difference is in what you do to the valve body. Stage 2 will shift down without the lever being changed and will drive automatically in D. If you start off in D in a stage 3 trans, you take off in 4th. B&M kits are different.
    VP Commodore
    Apr 2007
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    VP Commodore
    Apr 2007
    oh ok, so theyd be good against manuals etc?, because at the moment, im just getting owned by manual commodores lol...
    Morton's Avatar
    May 2006
    The condition of the car has a lot to do with it aswell. Given two perfect VPs, I'd be inclined to say a shift-kitted auto would consistently out-run a manual with an average driver.
    I know mine can out-run a manual VT... but it's a VT, so that's not saying much ^^
    1990 VN V6 Executive
    Jul 2005
    so how much does a transgo stage 2 & 3 shift kit usually go for? i see them on ebay for around $250 + $20 postage and comes with a corvette servo too, is that a good price?
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by mark_1000 View Post
    I paid $184 for the shiftkit and I think the corvette 2nd servo was about $60 or $80? I got a 0.500" boost valve too and a few other little bits and peices.
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
  15. #15
    Morton's Avatar
    May 2006
    I had my stage-2 with corvette servo installed for $150. I'd say market value would be between 300-400 installed. $150 was at a favour price, but I'd definately say it's worth around $250-300.
  16. #16
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by mulligan-can View Post
    Did you fit it all yourself or get it done by somewhere?
    Im still waiting. Its being installed and my trans rebuilt as soon as I get my car back.
  1. stage 2 shift kit
    By KingCoMMoDore in forum V6 Development And Modification
    Last Post: 08-04-2010, 11:33 PM
  2. stage 2 shift kit?
    By Sabby in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-01-2007, 12:13 PM
  3. vn stage 3 shift kit
    By VN-88 in forum Parts And Other Items For Sale
    Last Post: 07-05-2006, 10:24 PM
  4. stage 2 shift kits
    By hoon1 in forum V6 Development And Modification
    Last Post: 27-08-2005, 12:56 AM
  5. wtb: stage 2 shift kit
    By UNEQVN in forum Swap / Wanted to Buy / Trade
    Last Post: 27-06-2005, 08:59 AM
