will the twin fan thingoes on the AU falcons fit a VP? and would they be hard to fit/wire up?
Im not too sure. Have you checked the dimensions? Wouldnt it be easier just to get a Davies Craig (or the equivilent) fans wired up?
I FRYED RICE!!!
yeah shouldnt be too hard, they probably wont fit straight up but with a bit of cutting or adding in places, im sure it would work, as for wiring it up pretty sure there are only 2 wires on the Vn and 2 wires on the au fans
hmm excellent [= the main thing though, is it worth it?
Well first, you would need to find out just how easy it is to install & what needs to be done to fit it. (which is what you're trying to do now). Then you need to find out how much for the twin fan setup. Then you need to figure out how much can you do yourself?
I FRYED RICE!!!
why, save yourself some money and just install a thermatic fan switch, i have a turboed 6 and the stock fan does the job just nicely
