Results 1 to 8 of 8
Thread: It might be time for the VN to retire
    Commodore VN 3.8 / VP 3.8
    Apr 2006
    Auckland West
    Default It might be time for the VN to retire
    I have a VP and a VN, the Vn 89 3.6 has been off the road for a month as it is making a loud noise around the engine, when idling the noise is a vibrating rattle, when I idle it is still there but not loud, you can here it when you drive and its worse when foot goes down, tonight I started the car and there was smoke under the bonnet and it smelt like a lawn mower, any ideas out there?
    Mar 2006
    well cant really say where the smokes coming from? lift the bonnet and see wher e its coming from.. could be oil fom the rocker cover drippin on the exhaust headers
    VN CALAIS/VT executive
    Sep 2005
    Quote Originally Posted by modcon View Post
    is the noise around back of motor?....and is it auto? sounding like a flex plate,as for smoke,could be anything,from oil leaking onto exhaust,also another high possibility,could well be your timing chain tensioner has been chewed out.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Rattling could be anything from a botched big end to a drive plate. Can you crawl under the car and identify how far back it's coming from?
    The smoke could be from an exhaust gasket, or as samuels suggested, burning oil.
    The 1972 HQ Kingswood
    Apr 2006
    Auckland West
    Sounds like the noise is coming from the backend of the engine - towards the auto trans
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    I know you said its coming from the rear of the engine.. but have you checked the harmonic balancer by any chance? i kno my VP made nasty rattling sounds both idling and driving when the balancer went. i thought id blown the donk
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    Sep 2005
    get a small piece of garden hose,place it on top of bell housing,if it's flex plate you will hear it thru the hose,you may have to increase the idle speed,get someone to help,stand at side of car,place hose like suggested,get some one to sit in car and put in R or D and put a few revs on it,handbrake on firmly,it will start making a noise. rattly kind of noise more so
    Apr 2006
    Auckland West
    Quote Originally Posted by samuels View Post
    Yes it seems the flex plate is split, I understand to fix this the gearbox needs to be removed also the torque converter distatched, how long do you think it should take to do this job? I had one garage quote me 6 hours which I think is a crock
  1. Shane Warne to retire?
    By minux in forum The Pub
    Last Post: 21-12-2006, 05:07 PM
  2. 1st time
    By Infus10n in forum Jokes/Humour
    Last Post: 26-06-2006, 08:04 PM
  3. XR6 0-100 time
    By S Pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-05-2006, 12:02 AM
  4. What Time Can I Do
    By tuffvn in forum General
    Last Post: 26-02-2004, 01:13 AM
