Results 1 to 6 of 6
Thread: Where can i get Vaccum now that i have supercharged my car??!
    VR Calais 5ltr
    Feb 2006
    Default Where can i get Vaccum now that i have supercharged my car??!
    Hey guys, as the title suggests, I've just put a CRS supercharger on my series 1 V6 Vn and im trying to find somewhere to hook my BOV up to but every vaccum line is now running boost through it:my:. I have seriously looked everywhere, charcoal cannister, fuel reg....Its all boosting now... There has to be a simple answer to this. I must just be missing something. Any help is much appreciated ...Tim
    anton1o's Avatar
    anton1o is offline [GMHVN6]
    VN 6 Berlina '90
    Jan 2005
    West Subs,Melbourne
    atmo it :P
    ride; [GMHVN6] Project Streeter - VN Berlina '90 mods; 65mm throttle-body / Cold Air Intake / 8mm Ignition Leads / Exhaust
    future; Extractors , Cam currently; 101.2rwkw mission; 110rwkw
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    my instructions told me where to get it
    its from fuel reg line is where i got mine
    back of p/chamber
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    when you are off the throttle at idle with the blower on there will not be enough boost to stop a vacume, so any of the vacume points on the plenum/ manifold should be fine. when i did my cousins we ran it from where the pcv valve used to be hooked up. it worked fine
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    VN Commodore
    Feb 2006
    drill a hole in the elbow, then tap a thread and put a barb in. that is what i did. works good
    Matt_vp's Avatar
    Matt_vp is offline Donating Member
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    i run my bov vac lin off the map sensor vac hose and it works good and i have my boost gauge going off the fuel reg, i used to have the bov running off the fuel reg and it worked fine aswell, they are only under boost when the throttle body butterfly is open and have vacume when the the butterfly is closed which is when u want the bov to vent the excess pressure, so when u are on the throttle the bov isn't working and when your foot is off the gas the bov is working, but as defa said u r better off drilling and taping a seperate hole for bov and boost gauge, i will get around to it one day.
    hope this helps
    Matt
    VP TURBO WAGON --13.04 @109mph >>>>>http://forums.justcommodores.com.au/...-vp-wagon.html
    Never tell your problems to anyone...20% don't care and the other 80% are glad you have them.
    - Lou Holtz
    Found my reply helpfull? Share the love and click the star down the bottom
  1. Air Conditioning Vaccum
    By BlackCougar in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-02-2007, 09:09 PM
  2. Vh vaccum hoses
    By VL Racecar in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-12-2006, 11:13 PM
  3. Throttle body vaccum
    By VT97 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-04-2006, 09:08 PM
  4. Vaccum Ball
    By timboss04 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-09-2005, 03:41 PM
  5. Vaccum Ball
    Last Post: 25-09-2005, 08:23 AM
