Results 1 to 6 of 6
Thread: How do I remove VP Harmonic balance Part 1
    VP Commodore 96
    Aug 2006
    Default How do I remove VP Harmonic balance Part 1
    The biggest problem I face initially is, How do I stop the engine from turning as I try to loosen the crankshaft bolt from the harmonic balance?
    I dont have access to a good workshop to make a lot of stuff, and am no where near any shops (out in the sticks here)
    I can probably get the harmonic balance off with the usual bar+screw driver+brute force thing, all just to replace the bloody crank angle sensor. What a stupid place to put such a thing ! The fan belt broke, wrapped about inside the harmonic balance, and destroyed the CAS.
    anyway, maybe I can get a small rattle gun to it, but I stil lneed to stop that crank from turning.
    thanks
    VN Wagon
    Feb 2005
    VP Commodore 96
    Aug 2006
    Default Replaced CAS -Ran for ten, fifteen minutes - now wont start!
    Well, spent the whole day on this thing. 5 Bloody hours! Got the harmonic balance off finally. replaced the CAS, checked everything out, double checked it all, replaced everything, started car. Fired fist crank, and ran sweet as a bird. Drove down the road, stopped twice, restarted, probably covered 6 to 10 kilometers max, pulled up at the house and switched off.
    Loaded the boot, hit the starter - crank crank crank .....!!!! what the hell !!!
    That acar now wont fire up at all. Lights are on - nobody is home. Dash lights on, cranks over - but simply now wont start.
    Its behaving just like it did when the CAS was broken. But this is a brand new one, the car ran fine for a while, and now just wont start at all.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Did the plug fall off the CAS? Check that, if its still there, pull it off make sure its clean and plug it back in, push it hard and you will feel it click in.
    My00 Wrx 240kwatw
    Apr 2005
    vp vactioner wagon
    Mar 2006
    also make sure u have the same harmonic balancer as there are about 3 different types!! i installed the wrong 1 on my vp and when i started it up it started idled then died..........the harmonic broke my crank angle sensor!! so make sure u have the right size harmonic as the grooves on the rear are different between each 1!
  1. Do i have a balance shaft?
    By Bent_6 in forum General
    Last Post: 08-03-2007, 10:03 PM
  2. Remove Harmonic Balancer to change Crank Angle Sensor?
    By aklahr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-02-2007, 09:18 PM
  3. t5 balance weight
    By Calais_5sp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-02-2007, 07:03 AM
  4. Alignment or Balance?
    By majobe in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2006, 10:53 PM
  5. harmonic balance?
    By genuinepower in forum General Discussion
    Last Post: 28-12-2005, 08:00 AM
