Results 1 to 8 of 8
Thread: broken exhaust
    Nov 2006
    Default broken exhaust
    hey i have a problem the pipe leading from the last mufler (stock exhaust) has smapped off. it is hangging there i have tied it up so the cops dont c it what i need to know is will it be of to drive (rainning atm) untill i can get my sports exhaust fitted thanks
    AttaBoy is offline WTF?!?!
    VS Acclaim V6
    May 2005
    I don't really understand what you 're trying to say, but it shouldn't fall off if you tied it properly.
    It only cost around $300 to $350 to get a nice 2 1/2" Redback exhaust.
    dufus is offline Donating Member
    rickshaw
    Jun 2006
    Quote Originally Posted by Ben. View Post
    So all of the exhaust gasses are escaping before the rear muffler ??
    Nov 2006
    no not b4 the rear muffler after the 20 cm pipe that leads out that his the tip on it has fall off
    rickshaw
    Jun 2006
    I think that by law an exhaust must pass the rear door, so if it is past there then you should be alright, if im correct about the law, please correct me if im wrong.
    VS Acclaim V6
    May 2005
    Ohhh, its the tip, I thought its the whole pipe after the rear resonator. Cops shouldn't book you for that.
    Nov 2006
    VS Acclaim V6
    May 2005
    I don't really see how the water would get in, but it shouldn't be a big problem as they would just turn into steam if the pipe is hot.
  1. Broken Exhaust Stud
    By ivaninoz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2007, 07:05 AM
  2. HELP, broken exhaust
    By akallabeth in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-04-2007, 01:19 PM
  3. VT rear left exhaust manifold stud broken, remove with easy out or don't attempt
    By muso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-02-2007, 02:38 PM
  4. new exhaust and broken swaybar link
    By ultimate_vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-03-2006, 09:33 PM
  5. Broken Exhaust Studs
    By Sick Blue VL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 31-07-2005, 09:51 PM
