Results 1 to 7 of 7
Thread: Physical size difference VN vs VS motor
    vn s1
    Apr 2007
    Default Physical size difference VN vs VS motor
    Gidday, I'm putting a VN motor into a chev chassis. I've been chasing a dirt cheap stuffed motor to use as a mockup in the chassis for setting up clearances and engine mounts. The only motor I can find locally is a VS motor.
    1. In physical size, are these two motors about the same?
    2. Are the engine mount points the same?
    3. How different (in size and shape) is the series1 VN sump compared to the alloy VS sump? - ie could I roughly tack the s1 sump onto the VS motor to use as a guide for cross member fabrication?
    Nothing has to work- it will just be used as a dummy setup
    Thanks and regards
    Scoots.
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    the blocks are very similar in size, except that at the top, the vn motor sits about 1" higher and maybe 1/2 -1 inch wider, so the heads, manifold etc sit higher and wider by say an inch each way.
    pretty sure the mount points are the same, but get someone to confirm that.
    you should be able to bolt a vn sump onto the vs motor without problems.
    im surprised you cant find a dead vn-vr motor locally, theyre so easy and cheap to get. where about are you?
    vn s1
    Apr 2007
    I'm in Cairns mate. Apparently dead VN motors are so common down south that people trip over them walking down the street Up here things seem to be a bit different.
    Sounds like the VS motor might do the job. Height won't be a problem and the width shouldn't affect anything.
    Thanks for your help.
    Can anyone else confirm engine mounting points are the same?
    Regards Scoots
    vn s1
    Apr 2007
    Don't worry - problem solved. Just picked up a whole car (89 series 1 VN) for $40 from the council auctions. Can't wait for the Mrs to get home from holidays and see it
    Scoots
    hakhawk's Avatar
    Jan 2005
    haha, nice. nah, strip it bare, sell the shell for scrap metal and flog everything off for a profit which can go into the chev(what is the car its going into anyway?) all without the mrs knowing youve got some play money
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Quote Originally Posted by scoots View Post
    Scoots
    i'd be in the dog box if i did that here. good to see we all feel the same
    Body by Holden, Soul by Brock
    the Legend will live forever
    vn s1
    Apr 2007
    Well my Mrs should be used to it by now
    I've got a 1990 VN 5 speed that I will be using all the running gear out of and putting into my '47 Chev coupe ute. The $40 one allows me to keep the 1990 as a runner for a while longer.
    Regards Scoots
  1. vs v8 man. starter motor difference????
    By Bluewildangel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-11-2007, 10:12 AM
  2. will a manual box starter motor fit on a auto box motor?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-09-2007, 05:17 PM
  3. wagon V sedan size difference?
    By HoldenMad in forum General
    Last Post: 15-10-2006, 11:35 PM
  4. What size amp for 6x9 and what size amp for subs
    By Infanti in forum Car Audio
    Last Post: 12-10-2006, 07:28 PM
  5. wheel size question take off difference
    By VNPOWER in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-08-2005, 02:33 PM
