HI I KNOW HOW TO CHECK 4 ERROR CODES ON THE LITTLE PLUG NEAR THE COMPUTER BUT I CANT REMEMBER WHERE I STICK IN THE LITTLE PAPER CLIP SO I CAN GET A READING CAN SOMEONE PLEASE SHOW ME A PIC OF THE PLUG AND WHICH TERMINALS I STICK THE PAPER CLIP IN CHEERS![]()
black and white cable on one side of the connector
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
Checking your Computer for Faults (VN - VP)
Here is the How To with pics of the plug.
Is your capslock key borked or something? Use lowercase - uppercase is for shouting.
Obviously you DON'T know how to check for error codes then lol. If you know the right plug find the black wire and the white wire with the black stripe. Once you find them 2 wires you get the paper clip and put it into the terminals, turn the car onto accessories and if you hear the engine fan then you've done it correct. Count the number of engine light flashed to reveal the hidden code, if its 12 then its fine. Be sure to remove the paper clip after done. To count the flashes remember it flashes each number separate, for code 12 it will be *flash* pause.....*flash**flash*. Hope you sort it out.
