Hi there, my fog lights will only come on with my park lights does any one know how i can change it so they come on with my head lights as well?? Thanks
they should stay on with the headlights as the parkers are on when the headlights are on
Nah its to do with the loom for foglights.
They turn off the headlights if u turn on the fogs.
Im goin to wire mine up to the headlamp switch with a switch inbetwween for the fogs.
Then they can be turned on without the headlights turning off.
Just be careful when running the foglights and lowbeams on at the same time, from what I understand they both share the same wires/circuit for power. Therefore running both at the same time can potentially blow the fuse, and melt the wiring in the worst case.
Yeah goin to up the guage wire too, then i can run a higher Volt thru the fogs. Those wires can only just handle the power thru them atm, any more n say hello fire.
on my VP SS, the parkers in the fog lights only come on when parkers are on, but when lights are on, the fog lights come on aswell. i wanna hook them up so i can have the fog lights on with out the lights being on
i know this old but ive got a vs caprice body loom in my vp calais and so i have the factory loom for the fogs. mine only come on with parkers and high beam no low beam unless i switch the fogs off i want them on with the low beam aswell. also are they fog lights or driving lights?
WTB: VY/VZ front buckets any spec
WTB: VR/VS right hand side doors preferably white with electric motors for windows and locks
