T
Tadeusz
Guest
I'm currently in the middle of replacing the S1 VN motor in my Hilux with a VP motor. The motor I picked up was originally an auto, and I'm running a manual in the Hilux.
I've pulled the spigot bush out of the VN, and the dude at the clutch shop tells me it should be the same part used in the VP. I pulled the flex plate off the VP and the VN spigot bush is too big (around 27mm OD whereas the hole in the VP is around 20.4mm). Is the spigot bush supposed to be the same?
Looking at the VP, there appears to be an insert in the end of the crankshaft. Is this supposed to come out when converting to a manual so the spigot bush will fit? If this does come out, how do you get it out? There's nothing to grab onto, and it seems pressed in pretty firmly. I can probably get it out by destroying it, but I want to confirm that it's supposed to come out first.
Thanks,
Scott
Thanks,
Scott
