Results 1 to 8 of 8
Thread: power steering fluid leaks right out in about 5 minutes..
    VP Commodore
    Apr 2007
    Default power steering fluid leaks right out in about 5 minutes..
    hey im having a serious problem with my powersteering. As soon as i put power steering fluid in the power steering box, it leaks out from somewhere. I am about 75 percent sure the leak is comming from behind the power steering pulley just below the box, is there a plug behind that, that could be loose? also could it be leaking from anywhere else because other than that i cannot find any other leaks. I just really need to get this fixed because atm im back in the 40's...
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Check the hoses that come off the pump. It could be leaking from the front seal, although it would have to be totally rooted to leak that fast.
    LowVp's Avatar
    LowVp is offline VP nut
    VP Ute 3.8T M5
    Aug 2005
    Ipswich, Qld
    this happened to me on my first vp, the seal ends in the left side of the rack had come undone causing all the oil to just fill the rubber boot up and then slowly leak onto the ground, have a look under your car and check the ends for oil
    VP Commodore
    Apr 2007
    how do u take that pulley off? the power steering one? because its leaking from behind that really fast like up in behind it. i wana take that pulley off to see where its cummin from but i cant undo the nuts without it spinning?
    VP Commodore
    Apr 2007
    just took the pulley off, and it is leaking from the small steel wheel where the pulley spins on, not from the box, how do i fix this? anyone have any idea?
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You will need to take the shaft out and replace the seal. Not entirely sure how it's done on a VP as I've only done a VS one.
    vq~gangsta's Avatar
    vq~gangsta is offline Resident science geek
    VQ Statesman 5.0L
    Oct 2005
    Personally, i would just replace the pump with a second hand one from the wreckers- just make sure you get at least a month's warranty on it!
    I'd rather push my Holden than drive a Ford
    VP Commodore
    Apr 2007
    yeah im thinkin the same thing lol...
  1. Power steering fluid
    By 14000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-08-2007, 05:41 PM
  2. VT power steering pump fluid
    By Choc_4180 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-07-2006, 10:46 AM
  3. Power steering fluid leaking
    By Aryashahin in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-06-2006, 07:58 PM
  4. Small annoying oil leaks - power steering.
    By Marks-VY in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-04-2006, 09:20 PM
  5. Power Steering Fluid?
    By Cody in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-07-2005, 03:58 PM
