Results 1 to 12 of 12
Thread: Automatic stalls?
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    Default Automatic stalls?
    When first starting up from cold (usually in early morning before theres enough heat around i guess) my car is running rich (can smell fuel) and idles really really low and occasionally actually stalls?!?!
    The coolant probe is busted (according to the ALDL test thing) and thus the fan comes on the moment you switch the ignition to ON (and the thermostat opens as well I'm assuming, can't hear it over the fan ).
    Would the fact that coolant would be running through the engine all the time be the problem here?
    I'm at a loss, perhaps dirty injectors? (have some cleaner, going to dump that in soon enough)
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    i think you just answered your own question here - get a new coolant temp sensor.
    without the sensor working, on a cold start it's probably reading zero and therefore adding lots of fuel to try warm up the engine - this is probably messing around with the IAC as well and then it stalls because its just too rich and there's not enough air being let in.
    with the fan being on all the time, which is a safety thing as far as i know for when the pcm doesnt read any temp from the temp sensor and it'll run the fan incase its overheating, because it doesnt know whats going on - they biggest problem you'll have (besides your stalling cold starts) is that it'll be running at a cold start fuel map all the time and use lots of fuel.
    Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    Ok. Cool. I was just having to double check that .
    Just checking though.... I get "Code 15 - Coolant temperature Sensor - Voltage Too High" when I short the ALDL. This obviously means the coolant temperature probe is shot . However I was thinking voltage too high might mean that it was going to think the engine was hot?
    Either way, if no one can come up with anything other than "its all the coolant probes fault" I'll be really happy
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Yeah but it really shouldnt make it stall, in my old VN it used to stall n not run right when cold, got a TB clean n she was sweet, was just crap built up on the sensor in the throttle body.
    I had no thermostat, car ran dead on zero when u were moving.
    ________________________________________
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    Rrrr. Well, it runs rich on starting while cold in the morning and stalls .
    I did clean the IAC not too long ago to so its not that.... I'm just going to pray is the coolant sensor
    Need to get down and order a new one sometime soon I guess -sigh-
    VP V6 Executive
    Jul 2005
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    92 VP Calais 3.8
    May 2006
    Gold Coast
    He means the ECU, the computer behind the left hand side kick panel.
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    -sigh- I thought as much. I wouldn't think that those would ever really fail though? Wouldn't the engine play up constantly if the comp was on its way out?
    92 VP Calais 3.8
    May 2006
    Gold Coast
    yeah it would play up all the time, if the puta was playin up.
    The only way to check is to get another puta n put it in and see if it makes any difference
    VY SV8 HBD---mmmm LS1
    Simon Champion! On The Volley Champion! Shootin Hoops Champion! Batting Champ Champion!
    Dec 2005
    Western Suburbs
    does it stall any other times like if ur sitting at lights after its warm if so its most likely the cCAS
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    Nope, only stalls when it's cold. Hence me assuming it was the coolant temp probe's fault only lol
    Oh and it only stalls when cold if you try and open the throttle (even a crack).
  1. Help car stalls
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-12-2006, 08:37 AM
  2. stalls when hot
    By radiohead in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-08-2006, 10:40 AM
  3. stalls
    By sulley in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-07-2006, 08:29 PM
  4. Stalls
    By msh_crew in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-10-2005, 10:45 PM
  5. Vp V8 Stalls
    By finarfin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-11-2003, 10:30 PM
