Results 1 to 6 of 6
Thread: vp rear coolant connector
    fishman's Avatar
    fishman is offline fishman
    VN Executive Wagon S2runningVP motor on dual fuel
    Nov 2006
    east coast tasmania
    Default vp rear coolant connector
    yeah g'day can anyone tell me the procedure for removing the rear coolant connector holden part number 92061300 (the little plastic pipe at the just under the throttle body at rear of motor its the pipe that the heater hose returns to motor (bloody plastic) any help would be muchly
    VN Wagon
    Feb 2005
    Do you mean this one?
    If so then just undo the hose clamp (its a bit tight to get to) and the clamp onto the back of the block.
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    hmmmm usually they are brittle and crumble from age.... ive started using a thick 50mm coach screw and screwing it in there after the retaining bolt and hose is undone and pulling it straight out in one piece.
    its sometimes alot easier to take the whole manifold off lol
    fishman's Avatar
    Nov 2006
    east coast tasmania
    Default a 50 ml coach screw aye
    yeah might give that a go hey what actually holds it in is it just the retaining bolt gonna try to do it with the throttle body in place
    '94 VR Commodore Executive
    May 2006
    sorry for reopening this old thread, but there is a new brass adapter by kilkenny castings (part number: KC38MC) thats available. I bought one from work (repco) for the day that mine does crack. It comes: the adapter and seal as one piece so you won't have to get it from holden.
    See My Ride: VR
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    Seeing as this one's already been re-animated, if I intend to replace these things, I use a big pair of pliars, crush them flat, and pull them out... Works every time like a charm. Mind you, this is a lot simpler if you remove the valley cover and do it on a bench.
  1. Diagnosis connector pin lable for VX
    By VXcharged in forum Electrical Wiring / Questions
    Last Post: 21-02-2007, 06:58 PM
  2. VK dash connector
    By robbo10 in forum Electrical Wiring / Questions
    Last Post: 30-01-2007, 12:29 AM
  3. Where is the diagnostic connector?
    By AirStrike in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-08-2006, 10:13 PM
  4. Missing Connector
    By vn_calais in forum Car Audio
    Last Post: 07-02-2006, 02:27 AM
  5. So....where to get the OBDII connector in Oz
    By Clacker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-09-2005, 12:20 PM
