Results 1 to 4 of 4
Thread: Vns2 Crack In Block
    VNS2
    Mar 2007
    Default Vns2 Crack In Block
    Hi there my VNS2 broke down awhile ago i though it was the cas as my cas was loose and the bracket was cracked you could move the cas about 1mm or so side to side.Anyway i replaced it tried to start the car it wanted to it did start at one stage and really really idled roughly for about 30 seconds.Anyway i was having alook at my engine againe then notice a long crack in the front of the block.At the front of block where aircon motor sits in the crack started from ilke on that edge comes out then runs straite up the front of the block.What could cause this as it's pretty rear i've heard for a VN Engine block to crack
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    yeah the old GM Buick Block is pretty tough... they are pretty resiliant!
    Heat is a major caus eof cracking, it findds a weakness in the metal and stresses it. There are other causes but mainly heating and rapid cooling will do it.
    Luky there a dirt cheap block! just graba new one!
    aZk.
    Ps. Ive only heard of one other block related incident with these engines and that was when hozy lost a conrod through the side of his....
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    ive seen one do the same thing as hozy's.... i thnk you can get brand new cast blocks with no engine numbers from a joint in melbourne??? dont even have to change the engine numbers over
    Aug 2004
    lol the that would **** with vic roads
  1. Vns2 Still Not Starting Help Please!!!
    By robbovns2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-04-2007, 01:44 PM
  2. Auto Trans Query vns2
    By lazza44 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-03-2006, 10:49 PM
  3. Mystery noise in my vns2
    By H00LiGaN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2005, 12:12 AM
  4. 91 VNs2 v6 ppl.....
    By pathfinderus maximus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-11-2004, 07:27 PM
  5. Holden Vns2
    By Garth in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2004, 05:21 PM
