Results 1 to 7 of 7
Thread: VP commodore overheating
    abzy Guest
    Default VP commodore overheating
    I have recently had the water pump and thermostat replaced but my car still has overheating issues. Plenty of water and coolant in it and as i said new water pump and thermostat but its still overheating. I dont know much about cars so i was doing some research and found these forums
    Any help would be much appreciated.
    muzzvp Guest
    Thumbs up fuses
    check ur fuses in the fuse box and under ur dash to see if they r ok.or read the overheating post below
    AE86, VE M6 UTE, Toyota 86
    May 2004
    check if the thermostat is working properly first, place it in a tin of water and boil it. It should start to open.....
    Check if the top radiator hose gets hot, that can tell you if its circulating the water around.
    Check your guages are working correctly.....
    Check for any white goo in the engine oil or radiator, or run the car with the radiator cap off and check for any white bubles in the water (indicates blown head gasket). Turn off the car before the water level in the radiator rises too much...
    Thats just a few things to check, most importantly check if it has no leaks......
    Also, since you have had the water pump replaced recently, make sure you dont have air bubles in the cooling system. On the vp's, on the thermostat housing there should be a bleeder valve to let any air out of the system....
    Not really sure how to use it since i have a series one vn (the one with the thermostat at the back of the motor)....
    Hope this helps
    cliff_canon Guest
    have you had your radiator pressure tested.. they rekon its free.. it'll tell ya if your gasket is blown
    VP Executive
    Aug 2008
    A.C.T.
    Unhappy Cooling problems
    G'day, I am trying to find the name of a part. My commodore is leaking heaps of water out of the hose that forms the heater box bypass. When facing the front of the car, at the back left of the inlet manifold there is a hose leading down to a vavle or something that becomes the hose system for the cabin heating. It is that unit that hascorroded and is pouring out water and pressure when car is warm. if it runs to low on water and you pull up at traffic lights, it gets dangerously hot 3/4 and above on the temp. guage. As soon as I get some time off I am going to the parts store and replace it!!
    TVR-190's Avatar
    TVR-190 is offline Stelio Kontos
    Canyonero
    Jun 2008
    N.S.W
    Probably could have created a new thread rather then posting a reply in a 3 year old topic that isnt particularily related.
    Can you name the truck with 4 wheel drive, smells like a steak and seats 35?
    2007 WM Caprice
    Aug 2008
    If your unsure on the name / model of a part number, Give your local holden dealer a ring. As for spare parts, and explain to them what your after, they will figure out what your after, and will tell you what the part is called, give u a part number, and also a cost of getting a genuine one (good for comparisons).
  1. commodore vn overheating - help please
    By cliff_canon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2011, 01:08 PM
  2. VX COMMODORE thinks it is overheating
    By HoldenOwner in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-12-2007, 07:39 PM
  3. overheating vh slx
    By white vn ss in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-02-2006, 04:24 PM
  4. overheating!!!
    By Holdenboy_VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2006, 07:12 PM
  5. Is It Overheating Or What?
    By midnight.outlaw in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-02-2004, 06:49 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
