Results 1 to 11 of 11
Thread: Lowering a VN
    VN Executive Series 2
    Nov 2006
    Default Lowering a VN
    Hi guys,
    I know that this must have been asked before, but i can't make head or tails of all posts on lowering a VN.
    My question is can i have Ultralows in the rear, and superlows in the front (Kingsprings) or the peddlers equavilant? What shocks whould i need? I know i will need an adjustable panhard rod. how much roughly would this cost?
    Thanks in advance guys and girls.
    I love my VN
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    There is plenty of threads, I think you gotta take some time and find what your looking for tho.
    Anyway. Once again. Yes Ultras in back and Supers in from are the preferred choice for a level and low VN. I think my adj panhard cost like $110 or so. As for the shocks shortened ones will be needed for the Front, i'm not 100% on the rear tho, can someone else answer that one...
    LowVp's Avatar
    LowVp is offline VP nut
    VP Ute 3.8T M5
    Aug 2005
    Ipswich, Qld
    Nov 2006
    Thank you guys, thats wat i needed to know.
    I can get a panhard rod (new) from a mate for $70 so its going in regardless
    just need to round up sum money.
    I love my VN
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Just in my opinion, and I know this isn't the final truth, but I don't think you'll want Ultralows on the back if you want to handle well. I imagine having your car lean back + extra stiffness in the rear end will lead to cornering issues.
    Just my two cents though
    Personally, I went for Superlows on the front, and Lows on the rear - shortened Pedders shocks all around. leans forward a little, handles beautifully.
    The 1972 HQ Kingswood
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Quote Originally Posted by Morton View Post
    Yep. Lower at the rear than the front like that will give you cornering issues and wheel alignment issues on the rear which is not adjustable. You are better off lower at the front, as morton said. Lower at the rear just makes it look like your springs are sagging, very Elizabethan bogan style.
    Nov 2006
    Thanks guys, i was talking to a mate last night and he said the same thing.
    Also his tyres (17's) rub at the back, he has no panhard rod. If a panhard rod is installed will this stop the tyres rubbing, or will the guards have to be rolled??
    sorry about all questions but i just want do this right, heard to many horror stories with lowered cars. and you guys on this site are very knowledgeable.
    I love my VN
    Morton's Avatar
    May 2006
    Usually, when you drop the back of a car, the live rear setup moves to the side. If you're running 17s with wider tyres like 235s, then they will rub on the side your drivetrain has shifted to. An adjustable panhard rod allows you to re-center your diff, and fix the problem. OFC if you run 20s with 255s, they'll probably rub on both sides anyway
    VN calais 91
    Aug 2005
    i had superlows on front and lows on back
    i hated the look, looked like a dog with its arse up waiting for some action
    also caused alot of clunking in the back
    but then i got superlows all round and looks better now imo
    but each to his own
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Quote Originally Posted by Rogue VN View Post
    Rolling guards is a relatively easy procedure.. ^_^
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    38VNIT's Avatar
    38VNIT is offline Azerium
    nothing
    Jul 2006
    Inverell
    To Add My Own Question, I want the equivlant of superlows in pedders, done anyone know what these are and what it will look like and also what suspension will i need to accommodate these springs???
    If you do things righ people wont know you have done anything at all...
  1. lowering a VT
    By cameron4518 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-03-2012, 09:06 AM
  2. Lowering
    By watson01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-03-2007, 04:51 PM
  3. lowering my vy
    By fluxxx in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-10-2006, 11:53 PM
  4. lowering car
    By Moe in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-11-2005, 10:29 PM
  5. lowering??
    By noideea in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-09-2005, 09:17 PM
