Results 1 to 11 of 11
Thread: VN Flip box problem
    Dec 2004
    Default VN Flip box problem
    Earlier today I decided to clean out the contacts in my Power Window Control Module (located to the left of the fuse area.)
    I tried gently removing the 2 large coin screws (I can't think of the correct terminology right now) that hold up the 'flip box' with no luck, I then spoke to a friend who said just put abit of force into it and they should come out... still no luck, the screws didn’t even turn... by this time frustration was setting in so I decided to put excessive force on the flip box and finally got it in the 'unsecured' position, it was only then that I discovered what had happened.
    I can only guess this happened when I had a new immobiliser fitted, but it looks like the 2 lugs that are meant to hold the coin screws had been snapped off & that the screws had literally been 'melted' on to hold the flip box in the 'secured' position.
    So now I have no permanent way to hold the flip box in the secured position. At this very moment I have the right hand lug *just* holding on & supporting the box.
    Does anyone know if the lugs are screwed on or are part of the dash (which I hope not!)
    I am guessing you can still get the coin screws from Holden...
    If anyone could offer any suggestions it would be much appreciated!
    Thank you, (A very frustrated)
    Lewis
    AE86, VE2 SSV M6 UTE
    May 2004
    You should be able to get them from holden, i need to get one for mine (one has a hair line crack in it). They are buttons which that when they are turned with a screw driver they lock into position (like a right angle turn).
    Shouldn't cost too much for them....
    Off memory, they should look like this from side on.....
    Attached Thumbnails Attached Thumbnails VN Flip box problem-button_screw.jpg
    Darren's Avatar
    Darren is offline Site Administrator
    HSV Clubsport R8 E2 M6
    Feb 2003
    I bought them from Holden and from memory they cost no more than 50 cents each, they only had grey though which buggered me up but oh well.
    Dec 2004
    Thanks for the replies guys... sorry for not explaining better earlier, but my biggest worry was the mounting holes that retain the buttons.
    Are they just bolted/screwed onto the dash, or part of the dash? I would check mine, but I don't wanna pull open mine & completely stuff up the last lug.
    Oct 2004
    Padbury, Perth
    Hi MD 751,
    Sorry mate but they are part of the bigger dash frame. But you'd be right some one who doesn't understand these little coin turn locks has broken them off. I've seen work done by Stereo and immobiliser "fitters" an the work is atrocious. No solder just twists and tape etc. You'll have to live with. I dumped a dash two weeks ago but even if I lived next door and gave it to you - it's hardly worth the candle to fix it that way.
    Ciao.
    Dec 2004
    Bugger...
    I guess I will just drill 2 screws into the dash to hold it up... unless anyone else has a better suggestion?
    VP Commodore
    Jan 2005
    coin screws are easily available from the wreckers if holdens dont have them.
    Zig
    Dec 2004
    Quote Originally Posted by Ziggie
    Zig
    Cheers for the reply mate... but as I listed above the coin screws are not my problem... its the plastic mounting brackets.
    I wish it was only the coin screws!
    VP Commodore
    Jan 2005
    dont be too rash in drilling holes, it may seem like a good idea at the moment but down the track, nine times out of ten you end up regretting your decision.
    Dec 2004
    I am open to any other suggestions...
    There is nothing to hold the existing coin screws in place ( it is holding on by thread by *this* much. It is also sagged on the right side as their is nothing for the coin to hold onto.
    I considered gluing it. Any thoughts? What type of glue would you suggest? Naturally it has to be able to come off if I ever need to change a fuse.
    May 2004
    Maybe araldite a piece of plastic of similar shape and size to make the hole smaller. Then you could shape with a file...
    Remember, araldite is just perspects
  1. How-To: Flip Trunk Lid
    By harvma20 in forum Holden Commodore How-To's
    Last Post: 31-05-2011, 09:22 PM
  2. calais flip front wiring?
    By hosedogg in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-03-2007, 10:16 PM
  3. VE Flip keys?
    By aperfectcircle in forum Electrical Wiring / Questions
    Last Post: 07-01-2007, 02:33 PM
  4. DVD in VY- flip or not?
    By 03vyPplater in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-11-2006, 03:51 PM
  5. my VL CALAIS headlight thingys wont flip up!! ggrrr
    By tipsiegypsie in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-09-2006, 10:06 AM
