Results 1 to 4 of 4
Thread: VN Driveline Issues...
    VP CALAIS 5.0LTR + VP Wagon 5 spd
    Feb 2007
    Mannum, South Australia
    Default VN Driveline Issues...
    I have recently discovered a slight thumping in my driveline when i jab the accelerator and also when im accelerating and the release the pedal quickly. It also does it occasionaly when the car is naturaly deccelerating. Could this be my uni joints? or is this just wishfull thinking..
    thanks guys
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Sounds more like the centre bearing mount on the tailshaft. The rubber splits and the centre bearing thumps against the floor.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    center bearing is more likely nad a common problem on older commodores. check the unis also, however you'd notice a single clunk when you either step on the gas fromcoasting or when you let off the gas from accelerating etc
    Body by Holden, Soul by Brock
    the Legend will live forever
    VS II V6 Berlina
    Nov 2005
    I had a VN 5speed man on it's ar$e and when I nailed it I used to get a thump through the floor. Look above diff pinion and see if diff is hitting the floor.
  1. driveline clunk vy
    By vs hay hauler in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-04-2007, 06:06 PM
  2. driveline vibrations
    By v unit in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-05-2006, 11:30 PM
  3. VT driveline.can I start it out of the car?
    By petespipes in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-04-2006, 10:30 PM
  4. Problem with VN driveline
    By vinnywelsh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-08-2004, 02:03 PM
  5. Driveline vibration
    By Bulldog in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2004, 12:02 AM
