Results 1 to 5 of 5
Thread: heater tap
    Jan 2007
    Default heater tap
    wheres the heater tap located in a vp
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    driver side of the engine bay, next to the exhaust manifold, screwed in to the bay wall
    Jan 2007
    thanks for your very quick response i apreciate it how hard is it to replace it can it be done by the owner or is it better to pay a mechanic
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    easy to replace just need a socket like 10mm or something and a screw driver. they are easy to break then the plastic goes soft. but its already broken by the sound of it.
    13.3 1/4 exhaust only untuned!
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    yeah, but if you can, pull it out and bring it with you to autobarn or wherever, cos there are a couple of types, one with 5 connections and one with only 2.
    at first when i described the straight through, they sold me a ford one
    which had the wrong pipe size.
    also if your hoses are on the way out, it might be a good time to renew them, or at least check the endpoints your joining up again for perishing/cracks/hardness
    mine had this so i had to redo it all again to swap it.
    if you do it right it's only a 1/2 hour job, and piss easy
  1. heater tap
    By 12000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-05-2007, 09:52 PM
  2. vl heater box will fit in a vh??
    By lil_oneblue in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-02-2007, 07:05 AM
  3. Heater Tap
    By vl1234 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-09-2006, 08:42 PM
  4. Heater
    By pj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-01-2006, 09:40 PM
  5. heater tap
    By markovr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2004, 04:43 PM
