Results 1 to 9 of 9
Thread: Dry noise from engine
    MontyMan250 is offline Xrandom
    94 Fairmont
    May 2007
    Default Dry noise from engine
    G'day guys,
    I don't have a Commodore (got a Fairmont...), but please don't flame me for it as I'm coming here to try and get info for a workmate who says he thinks he has a VN (I haven't seen it)... but doesn't have the internet to get on here. Anyway he says that there's a noise that sounds like a dry-bearing or something similar coming from his engine. He's recently replaced the water pump on it, and he says that "the bottom pulley wobbles while the engine spins" so not being familiar with these motors I just assumed it might be the balancer?? *shrug*
    I've told him not to rip the motor apart yet until I find out for him if there are any common problems with these motors -- is there a tensioner pulley on these at all like what's on the Falcons? The one on my car had a dry bearing so I had to re-grease it, I'm thinking maybe these might have a similar problem? As I said these are alien to me, so try not to treat me like too much of a knobhead, and yeah if there are any common problems that are easily remedied then please tell me all about them!
    Cheers,
    Jais
    pr0n's Avatar
    pr0n is offline It's A Me ' MARIO '
    03 VY II S V6
    Dec 2006
    Gladstone
    the bottom one right in the centre is the harmonic balancer. get that fixed asap.
    94 Fairmont
    May 2007
    definitely the balancer?
    If so what's involved in removal? Just belt off and then a few bolts and the balancer comes out?
    spacattack's Avatar
    spacattack is offline THE ENFORCER!!!
    Custom VN
    Mar 2005
    brissy
    yeh take the belt off, undo the main bolt, chuck a balancer puller on it and itll just pop off, also replace the CAS to ( crank angle sencor )
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You may need to use a puller depending on whether it's a series 1 or series 2.
    And yes, belt off, big bolt in the middle of the pulley undone, then if it doesn't slide off easy, a puller is needed.
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    yeah there's a tensioner pulley, it's a spring loaded pulley should be a small pulley slightly to the left of the power steering reservoir. doesn't come off, but if you use a spanner on it you can lever it up to take the belt off
    94 Fairmont
    May 2007
    awesome thanks guys. Any idea how much a new balancer and CAS retail for?
    spacattack's Avatar
    Custom VN
    Mar 2005
    brissy
    94 Fairmont
    May 2007
    cheers mate, much appreciated
  1. engine noise
    By reg9128 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-01-2007, 05:45 PM
  2. engine noise!!!!
    By [SIK-GMH] in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-08-2006, 06:01 PM
  3. Help with engine noise
    By vl8 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-02-2006, 12:33 AM
  4. engine noise. need help
    By matrix in forum Car Audio
    Last Post: 15-11-2005, 11:06 PM
  5. Engine Noise....
    By stheggie in forum Car Audio
    Last Post: 30-04-2005, 12:39 AM
