hey guys i was under my car at work the other day and i noticed a wet patch around the bottom of my filler neck of the feul tank so i gave the hose clamp a couple of turns it was pretty easy so i thought that might fix it but now when i fill the car up feul runs out of it and its not full as i ran it dry the other day, does anyone know what the hose would cost to replace or should i go for a new tank, a larger one and if i do will it bottom out on superlows with 17"s as they are getting installed later this week, or woudl it be something else???
Big Ideas, Big Plans, Low Cash flow, 1st yr apprentice,
3.8L V6, Pod, Stereo,Mags lots more planned
Vn 3.8L V6 II
in the wheel arch near the filer neck there is a plate screwd in. pull that off and make sure all your hoses are conected to the tank
Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
MY RIDES
[SIGPIC][/SIGPIC]
http://forums.justcommodores.com.au/...ad.php?t=41837
thanks man, i had a look a work to day and adjusted the main hose between the filler neck and the tank and made the neck sit in pcoperly and it stoped the leak, the clam was above the neck of the tank so the feul just ran around it. cheers mate
Vn 3.8L V6 II
