Results 1 to 9 of 9
Thread: The old VN aint what she used to be...
    vn 1991 executive v6
    May 2007
    Penrith nsw
    Default The old VN aint what she used to be...
    Can anyone help me with my old VN gal, after fueling up and driving approx 30km she started missing and the engine check light appeared, since then she will idle with a few misses and as soon as I try to accelerate the engine just misfires and will not rev out, it just coughs, splutters, back fires and stalls...I have replaced spark plugs and leads to no avail...Please help, the old girl has never missed a beat until now???... Bruno
    May 2007
    Penrith nsw
    it could be the fuel there has been fuel with water contamination going around
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    What kinda fuel was it and from what servo? You could possibly have water in the tank but I doubt it. Could be a blocked fuel filter or stuffed fuel pump.
    89 VN 5lt
    Mar 2005
    Busselton W/A
    you need to find out why your engine check light came on, then you will probably find your problem goodluck, it's sad when they are unwell
    Matt_vp's Avatar
    Matt_vp is offline Donating Member
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    there is a thead about how to check check engine light codes do a serch for that and find out the code and u might get an idea about what is going on.
    Matt
    VP TURBO WAGON --13.04 @109mph >>>>>http://forums.justcommodores.com.au/...-vp-wagon.html
    Never tell your problems to anyone...20% don't care and the other 80% are glad you have them.
    - Lou Holtz
    Found my reply helpfull? Share the love and click the star down the bottom
    May 2007
    Penrith nsw
    Default aint what she used to be
    Quote Originally Posted by 1991_Vn2nV View Post
    It was the one with 10% ethanol i got it from a united servo at St Marys
    it strange it just went after filling the tank and it got progressivly got worse.
    VN Executive
    Apr 2007
    Wellington, New Zealand
    run the onboard diagnostics, you mite have damaged a sensor or something.
    sounds like the fuel pumps slowly going, mine just went all of a sudden but did have what you described minus the engine light.
    May 2007
    Penrith nsw
    Thank you for your comment i will do that it may point me in the right dirrection.
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by trucky581 View Post
    Then it probably is the fuel as it just happens to be ethanol fuel you used and just happened to be straight after you got your fuel but run a diagnostic as everyone has said. Might just be spitting out an idle speed error but could be something completely different. Here is the link to the fault codes:
    http://www.justcommodores.com.au/art...omputer_v6.php
    And here is the How To on checking your fault codes:
    Checking your Computer for Faults (VN - VP)
    Ethanol mixes with water so if service stations that sell ethanol fuel get any water in the tanks which can be common, it mixes in with the fuel. Normal petrol sits on water and doesn't mix, never leaves the tank as it sits below the pickups in the tanks. With all the rain recently it is entirely possible that some water has gotten in through either the cap or when they were dipping the tanks or the most common way during rain which is through the ventilation pipe.
  1. Cruise control that aint cruisin.......
    By CountryPak in forum Electrical Wiring / Questions
    Last Post: 25-11-2007, 07:26 PM
  2. indicators aint workin pls help
    By blaze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-07-2006, 03:40 PM
  3. So Supercharging a VK 202 EFI aint worth it?
    By Mr Robbo - The General in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-06-2006, 07:56 PM
  4. my cruise aint working and i dont know why-plz help
    By shanhsv in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2005, 10:13 AM
  5. VY and VZ aint a good mix
    By commodore_vy in forum Site Feedback / Site Problems
    Last Post: 21-12-2004, 01:47 PM
