Results 1 to 8 of 8
Thread: stupid question... i know
    missmcudd's Avatar
    missmcudd is offline The Bee Sting butterfly
    Black Mini Cooper
    Jan 2006
    Carrum Downs.
    Default stupid question... i know
    where can i buy a new boot lock with keys from? ? i have a VP commodore... i know its a dumb question but i honestly have nooo idea and i need to find parts for my car!
    Also i need the centre console cover and i need it in blue... if i cant find it in the blue do you think it will look too dodgy if i put a black one on there? Or can you paint them?
    Im trying to get my car nice so i can sell it !
    take it easy and if its easy ....take it home!
    VZ
    Feb 2006
    SE.MELBOURNE
    Wreckers?. Go to OZwreck they should have the key with it www.ozwreck.com.au
    VR EXECUTIVE We had some good times
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    any mechanic should be able to hook u up with one if you dont wanna fix it yourself, otherwise i think holden still sell them new
    and centre console's can be painted.
    We got rep back, yaaay!
    vk 308
    Apr 2007
    VN Exec Wagon, 02 VX Calais
    Feb 2007
    Wollongong
    Holden quoted me $60 for a new wagon tailgate lock for my VN so that sorta gives ya an idea..
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    i think there's a thread in the vic members section about wreckers locations and stuff, give em a call around and the gregories manual probably tells you how to do it
    5sp VN Executive1988, VX SS 6sp
    Apr 2006
    canberra
    I got a new boot lock from wreckers for $20. But then another $20 or $30 i think it was to get it re-coded by a lock smith so all my locks take the same key
    Australia. Love it or leave it
    Bent_6 is offline 3/4motorsport
    VT S1 Acclaim V6/ VS SII Acclaim V6
    Jan 2007
    Just right of the redline
    Go to U-pull it or something similar where you can pull the part off your self.
    Grab a few and pull them apart its not hard.
    When you have stripped the guts out of the barrel you will find a heap of brass pieces that are numbered and have small springs on them.
    Pull them from the center carefully.
    Each number represents a different offset for the lock.
    Using trial and error, put one piece back in at a time so that when you put your key in it slides the brass piece level. Its hard to explain but you will see what i mean if you give it a try.
    Then continue with each of the 5 or 6 pieces until all holes are filled and the key slides in.
    When you have all the pieces back in insert your key and you will see all the brass pieces disappear inside the lock
    Put the center back into the barrel and turn it, if you have the right pieces in the right places it will turn.
    I did this with my VN door lock and it worked a treat, took about 20mins to get it right.
    Just make sure you get all the numbered brass pieces in the set, 1-8 i think
  1. Maybe a stupid question but still
    By Pretender in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-12-2006, 02:51 AM
  2. Stupid Question
    By hitman1979 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-05-2006, 06:39 PM
  3. Stupid Stupid Question
    By habro in forum General
    Last Post: 24-09-2005, 11:51 AM
  4. Stupid Question!
    By tr3nt in forum The Pub
    Last Post: 02-09-2005, 05:20 PM
  5. Stupid Question
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-03-2005, 12:25 PM
