Results 1 to 8 of 8
Thread: level 3 special features - AFR??
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Default level 3 special features - AFR??
    ok, so you know how with level3 clusters, you can hold reset and mode when you turn the car over, it gives you digital speedo, and some other stuff? after this i hit mode, and it gave me some other stuff. voltage and one marked 'fuel' that starts looking like 1:5.5, but varies (goes to 1:2.5 etc when it warms up, and when you rev it it goes up to 1:double digits.
    what is this, i heard its unlikely it's actually AFR so anyone else with a level3 tried this?
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Tried this when looking at my voltage. Also get a more accurate fuel usage when the engine is running and in park - normal read out is 0.
    1 mode is to test lights and lcd's.
    May have to go look at the book/s tonight and see what the go is.
    and 3 Dangerous non ABS VN's
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    i noticed the numbers were goin up when u rev'd it, if it was afr the numbers should go down, more fuel, less stoich.
    its almost like a fuel usage indicator, no idea what the first number is ie 1 & 2.
    VN v6 s2 Berlina 5spd
    Mar 2006
    more importantley,
    what does it say next to the numbers in the left hand corner?
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Quote Originally Posted by ashzv6 View Post
    more importantley,
    yeah that says fuel, that's what gave me the idea that it was an afr or similar. i just didn't know if it was relevant to anything afr-wise.
    VR Statesman, WK Statesman
    Aug 2006
    Let's work on the number 1: 6.7
    The 1 is just the number of the diagnostic test. The 6.7 is litres per hour of fuel used.
    Now 2: 6.6
    Once again, the 2 is the number of the diagnostic test. the 6.6 is the voltage coming from the fuel tank sender
    88GreenVN's Avatar
    Jun 2006
    This was put on a thread too so here it is
  1. Level 1 dash cluster to level 3
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2006, 06:28 PM
  2. Differenec between Level 2 and Level 3 Clusters
    By Fekason in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-08-2006, 09:35 PM
  3. Replacing level 2 cluster with level 3.
    By madmick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2006, 11:18 PM
  4. VS Level 1 to Level 3 Cluster Upgrade
    By Luv holdens guy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-02-2006, 01:28 PM
  5. VT speedo cluster "special" features?
    By bdcmedia in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-05-2004, 04:15 PM
