Page 1 of 3 123 LastLast
Results 1 to 25 of 68
Thread: Strange noise!
    PaRaDoX's Avatar
    PaRaDoX is online now boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Default Strange noise!
    sooo got my car boosted yesterday, spent a day playing with the tune before id even take it outta the driveway, soo today i got it out, anyway havnt hit massive boost, (nothing over 5psi) they're is plenty of fuel and i have a constant black fuel cloud following me when i boost (fixed now)
    anyway i went to a mates house, went to start it to drive home and it starting making a weird noise, we tried to figure out what it was, we tried a few things at his join (changed alt) suspected it was bearings on a fan belt item, anyway
    so i limped it home, it drove perfect except for a unbearable noise, anyway got home and the noise got alot louder,
    soo heres the noise
    YouTube - weird noise
    i went out and had a listen, sounds like its comming from the back of the motor now,
    has anyone heard this sound before as its kinda distinctive and odd
    when i changed my trans i swapped flex plates used locktite used a torque wrench, im gonna rip the insepction cover off and have a squiz tommorrow (god i love s1's inspection plate)
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Damn that is a weird noise. sounds like gulping air or blowing air idk it would be easier to tell if you could see and hear in person.
    Oh yeah love the dose vid
    matty88's Avatar
    matty88 is offline LPG Installer :p
    TEXXXY: Resprayed TX3 Non Turbo
    Aug 2005
    Doveton
    It sounds to me like noisy tappets/valves?
    If not check the fans, it sounds like it's hitting something....
    Just my 2c worth
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    broken balance shaft??? balance shaft bearings shagged maybe??? sounds pretty clunky lol too clunky for lifters anyways
    Jun 2005
    the massive suction from your turbo caused a duck to fly into your engiine
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Quote Originally Posted by Peanuts Inc. View Post
    Good call on that one i was thinking of it but never heard what it sounds like might also be why it sounds like its coming from the back but you thought it was at the front first
    Garth's Avatar
    Garth is offline Your guess is as good as mine......
    not telling
    Space Invaders Champion!
    Oct 2002
    manual or auto? it's changing pitch and speed when engine revs, sounds like loose or failing manual component, throw out bearing, or clutch. worse case is synchro's doing someting daft.
    sounds nasty but it's not a engine noise, gearbox related noise.
    if auto loose or failing torque conveter, or slipping or fialing compoent inside box.
    i am the god of britany spears womanizer on just dance on the wii
    Boonz's Avatar
    Jul 2005
    dont fix it just take it out lol.... ive only ever heard of them breaking ive never seen or heard one..... but theres not alot of things in a motor that can make a noise that pronounced that doesnt affect the running of the engine
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    yeah i know, well ive got a spare torque converter but for that id need to push the box back a bit to slide it out but its doable, eitherway, ill put the car on some sturdy stands start her up and see if i can hear where its comming from without getting under the car, cars too low atm to get a listen out,
    garth thanks for your insight, its a auto; isnt the torque converter like the clutch sooo when out of gear nothing past the torque converter spins or does it spin the whole trans and the gears grip as they want to?
    if anyone else is intrested in another strange noise my car started making today here it is
    YouTube - VN Calais Turbo (Dose pipe fitted)
    i took my time tripple checking everything this time to be sure that nothing was wrong, and i did 100km today on test drives and tuning on the street, the cars running 2 bar + big injectors..
    its not rockers/lifters/valves because i used a screw driver to listen in on what they were saying and they sounded normal, this noise was more like its out in the open rather than engine internal, it could even be something as spastic as the dump rubbing on the chassis/trans or something like that
    VP Executive R-spec
    Jan 2005
    vp calais
    Aug 2007
    this sounds like the same sound my series 1 vn had before the engine died, ended up being a twisted conrod or something arather, im not saying this is it but mine started off really soft then as i drove it go worse, it got really loud, bout as loud as yours is now and then the engine died, going out on a limb id say its something in your bottom end. tho i dont know much about engines, i no that sound is very simular to what mine made.
    missus (in more ways than one)
    Sep 2005
    i changed an engine because of the same noise, didnt need to thou
    i'm 90% sure youve cracked your flywheel,
    is it a bit hard to start now???
    because of the new found tourqe i reckon youve cracked it. when i took mine out one tap of the hammer and the whole centre part where it bolts the crank came out.
    and if you think about it is the weakest link, it transfers all the energy from the crank to the converter and it only a thin bit of steel, i got another one from comcar for $40, just make sure the teeth are in good condition, if it's series one make sure its the 6 bolt one and series 2 usees an 8 bolt crank.
    probally strart it, get a stethascope, and put it on the inspection plate (series 2) or bell mouth, and t should be a load clacking.
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Your converters stuffed!!!!!!!!!! Sounded like mine!
    You get that noise when you don't align the converter properly.
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    dont align the converter properly?
    ive got a spare converter anyway
    your right, it is hard to start its worth a check but i removed the inspection plate and the rear main has popped out a little, engine has to come out soon anyway i might remove it and take a look
  15. #15
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    if its the balance shaft you should be able to feel it through the inlet manifold most probably torque converter by the sound though bearing let go in the torque converter
    before taking the box out undo the converter and push it back into the gearbox then start it up with it disconnected see if the noise goes away
  16. #16
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    most likely, ill remove the inlet manifold and insepct the balance shaft, but honostly, a balance shaft is hard to snap considering it has no load on it...
    does anyone know the size of the welsch plugs?
    http://i29.photobucket.com/albums/c2...2072007314.jpg
    those 4 not on the head
    planning to hire a engine hoist next week and rip the bastard out
  17. #17
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    ohhh yeah its definiatly something round the converter
    YouTube - broken
    im going to unbolt the torque converter and try spinning the flex plate to see if the noise persists so i can check if its engine/trans related
  18. #18
    Aug 2006
    if the bearings gone in the T/C the impellor fins will be hitting each other and filling the trans with bits of metal unhook it and shove it up the box a bit fire it up it wont go anywhere
  19. #19
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    ok well its not the torque converter, i just started it up with the torque converter un bolted and it still makes that noise, they'res no load and no visable cracks on the flex plate so it shouldnt be that im thinking bottom end bearing? and the car wont stay running anymore its been hard to start when its cold because i havnt got round to the cold start in the tune but yeah this is silly cant keep it on for long at all, im thinking time for a new engine,
  20. #20
    Aug 2006
    bugger least youve got most of the experimenting out the way before you stick a new engine in so you think its bottom end noise as your final assesement then bigend gone or something or do you still think theres a posablity that it could be the balance shaft
  21. #21
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    im not sure, but the engine has to come out anyway, i wanted a excuse to start building a new bottom end for boost and i just got it anyway, my engines a virgin bore and it hasnt thrown a rod soo its good for a rebuild with some stronger bits, i have a large tax return due soon soo who knows
  22. #22
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Fkn hell man, you've had some rotten luck with this thing havnt you. Best of luck solving it.....Dose it.
  23. #23
    vp calais
    Aug 2007
    everyone ignores ol luke-o tho dont they! lol
    at least your in the rite frame of mind for it. rebuild time!
  24. #24
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    hehe not yet, if something bad has gone wrong in the bottom end ill rebuild that and stick another one in it for now i rather not be off the road for more than a week, walking down to the super market with a weeks worth of meet (45 min walk) isnt nice :P
    im going to remove the engine on sunday or wedensday if its a cracked flex plate or something thats ok i have another one here, i think i might find a broken bearing at the back near the rear main, maybe becuase of the broken rear main it got starved of oil, who knows ill know more on in the comming days
    BUT if anyone else has heard it and has any more theories on what it might be please tell me :P
  25. #25
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    a mechanic once told me a story about a run of V6 holden engines (3800) where the gudeon pin (from the piston) comes loose and touches the bore, don't know if it's true however. that does sound bloody awfull.
    you said it's been running very rich, you had any pinging/knocking when driving it. it does remind me of a failed bottom end bearing in my old 3.3
    Body by Holden, Soul by Brock
    the Legend will live forever
  1. Strange Noise...
    By Dazzamcgee in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2007, 04:13 PM
  2. Strange noise
    By VSAccCom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-10-2005, 01:25 AM
  3. VS Berlina 95 Strange noise Help?
    By Ryzza75 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-09-2005, 10:08 PM
  4. strange noise (you will think this is daft)
    By VN Shane in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-12-2004, 05:27 AM
  5. strange noise
    By Tony in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-05-2004, 10:37 AM
