Results 1 to 6 of 6
Thread: few questions
    1997 vs 2 clubsport
    Mar 2005
    Default few questions
    hey guys just a few queries on my vp series 2:
    1. my interior roof is sagging big time what is the best way to fix it?
    2. i recently was canaried for cut springs. i wanna get some king springs. should i go low or super low? as long as its legal lol
    3. my auto is slipping if it happens to **** itself how much would i be up for? thinkin a stage 2 shift kit.
    any help at all would b much appreciated thanks. cheers
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Best way to fix the roof, is to remove the entire lining. It's a bit of a pain in the arse, but once it's out you can peel off the material, and glue on some new material of your choice.
    And the auto... well, you're looking at quite a bit of money if you pay someone else to do everything. Stage 2 shift kits will set you back around $400 installed with a 1/2 servo piston, and will only make a slipping gearbox fail sooner - so you're looking at just dropping an entire 2nd hand transmission in and getting that kitted. Rebuilds are expensive
    The 1972 HQ Kingswood
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    superows are illegal, mine wouldnt pass a road with supers as the K frame was way too low... thats on stockies, 18's sit it legal.
    Pull The whole lining out and use spray on contact adhesive to restick the roof lining, do it in halfs as youll sun out of time(re drying) to do the whoe thing at once.
    Threres a how to around here some where.
    Auto, itll cost anywhere from $700 to $2000 for auto rebuilds depending on what you have done.
    Another auto can be sourced fro the $350mark.
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by Morton View Post
    Can vouch for that. I got a stage 1 shift kit (only because they woudn't warrant a stage 2 or 3) corvette servo and full rebuild (inc torque converter) I also had a heavy duty drive shell fitted and a transmission cooler. Total $2600. IMO I think I got a good deal, all was done in 4 or so days.
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by azkwazere View Post
    aZk.
    Hmm interesting. I have ultralow fronts and superlow rears and im sitting legal.
  1. CPI lpg questions
    By Outlaw Torn in forum General
    Last Post: 18-09-2006, 09:09 AM
  2. Two Questions
    By jamo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-09-2006, 10:21 PM
  3. A Few Questions
    By 4PLAYN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-08-2006, 10:29 PM
  4. 2 questions
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-09-2005, 03:54 PM
  5. VY 914 Questions
    By mungx2 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-09-2005, 06:24 PM
