Results 1 to 23 of 23
Thread: little red oil light
    VN calais 91
    Aug 2005
    Default little red oil light
    hi
    i tried a search, but being capped at 64kps makes it unbearable, plus i've never been able to find much with the search
    little red oil light (looks like a teapot) comes on
    use to come on when the ignition was off (almost drained battery)
    but now its off till i turn the engine on, and stays on
    i've topped up oil level, power steering and auto gear box. even did brakes and coolant
    still won't go away
    any other fluid i'm missing? diff? or is it pressure i'm out of? or a crook sensor?
    VX Executive Wgn, VP Sedan, V6 Ride on Lawnmower
    Aug 2007
    the little bugger shouldnt come on when the ignition is off! Sounds to me like you may have a short in the intstrument cluster or related wiring somewhere.
    Jasoniumh's Avatar
    Jasoniumh is offline Its a dogs life
    VP Commodore Executive 3.8
    Aug 2007
    Have you degreased your engine lately? Sometimes water gets in there and shorts the circuit, take it out and clean it out. But with it on with the ignition off? That sounds weird, sparky?
    VN calais 91
    Aug 2005
    i thought having it come on after ignition off
    was a common thing, to let you know next time to check the oils?
    no, have'nt degreased, but will keep in mind the sensor
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    That light will be an oil pressure warning light most probably. Don't drive the car and get a mechanic to come out and check if it really has no oil pressure or if it's the sender that is fubar. Starting the car with no oil pressure will cause major damage and it's only a matter of time before it either spins a bearing or seizes. If you are driving along and the light flicks on, pull over to the nearest safe stopping spot and turn off the motor immediately.
    Reaper
    VN calais 91
    Aug 2005
    thanks reaper
    thats a bit scary
    i've driven a fair bit with that light on, so now i'm a bit concerned as i had a full weekend planned
    is there anyway to suss it out myself?
    cheers
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by timmy_tam View Post
    thanks reaper
    thats a bit scary
    cheers
    Long shot but you could try resetting the ECU (main fuse out 10 secs).
    Are you getting any error codes - ie any thing esle playing up?
    Could be the oil pressure sensor connector - have a look for corrosion around it when you unplug it.
    and 3 Dangerous non ABS VN's
    Reaper's Avatar
    Aug 2004
    thanks reaper
    thats a bit scary
    cheers
    If you have driven it a fair bit without incident I'd suspect it is the sensor playing up. Go visit your local wrecker and get a new sensor to swap it over. Also check the wire is in good condition (and still attached).
    Sludge buildup in the oil galleries can also eventually block oil flow in which case you need a rebuild quickly.
    Reaper
    J_D
    J_D is offline
    VN S1 and VS V8 Statesman
    Jul 2006
    Ipswich. QLD
    By the way that light only indicates low engine oil pressure not engine oil level and isnt connected to the power steering, auto trans or diff, all those have to be checked by the dipsticks as well as the engine oil to ensure sufficient oil is in those systems.
    PRH
    PRH is offline
    vp s utility,and a KENWORTH
    Apr 2007
    Mildura Victoria
    Hey all,
    just a thought would'nt the fuel pump drop out with low oil pressure ?
    Phillip
    VN calais 91
    Aug 2005
    thanks all for the help!!! really really appreciate it!
    this is what makes JC such a great forum
    just a quick update, i installed an oil guage (will put up a HOW TO INSTALL if there is any interest)
    reads around 4 BAR under normal accelerating and driving, occasionally touching 4.5 when accelerating hard
    so i know i don't have low pressure
    might have high, as the gregory says MAX at 4.14 BAR
    but i think should be right
    cheers!
    Reaper's Avatar
    Aug 2004
    Quote Originally Posted by PRH View Post
    Hey all,
    Phillip
    Uhh no. Why would it?
    Reaper
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Reaper
    actually yes it would.
    ADR 27 1984 fire prevenion saftey unit cut fuel in accedent
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    Mar 2006
    Quote Originally Posted by burnz View Post
    nope if it loses oil pressure the car wont turn off, it will contiune to run until it either siezes or you turn it off, the only thing the oil pressure switch has to do with the fuel pump is, if the fuel pump relay dies it will get power to the fuel pump only when it gets oil pressure.. so it will crank for a while till it builds pressure then it will start.
    edit: also there is usually an Inertia switch in commercial trucks and vans, and some family cars that will cut power to the fuel pump in an accident. which would most likely be referring to the ADR 27 1984
  15. #15
    Reaper's Avatar
    Aug 2004
    Well I guess it would shortly after the engine seizes but it's hardly a direct relationship.
    Reaper
  16. #16
    pandaman's Avatar
    pandaman is offline Aussie Muscle Fan
    VN Berlina 5.0 A4
    Feb 2006
    News to me. If the fuel pump wouldn't run with no oil pressure, it'd be impossible to start the damned thing.
    cheers!
    Sounds damned good. That max value is a bit of a rough guide really, it's where the bypass valve is supposed to open, it's a spring operated thing so it's not really exact.
    Beau Duke: Man, I'm never gonna get outta this car again. I'm gonna live in it, I'm gonna eat in it and I'm gonna make sweet love to it!
    Luke Duke: You mean you're gonna make sweet love IN it.
    Beau Duke: Oh no, I'm gonna have sex with it.
  17. #17
    Aug 2007
    directly related to altenator, battery, key switch, and charging circuit. If they stop, it does too
    seriously though, a few relays and an LED later, and you could make an interlink that could save you a few bucks later on. link it up also to your immobiliser, and you are even better off. starting to sound like quite a sweet idea to me. until the relay goes pop and the whole thing goes balls up
  18. #18
    VN calais 91
    Aug 2005
  19. #19
    burnz's Avatar
    2010 CRUZE Diesel
    Jun 2005
    springfield
    light your ignition dont start fuel pump will turn off in three seconds
    also try reading your manuel
    the car starts on one relay then transfers too another
    Powered By Garrett
  20. #20
    VN calais 91
    Aug 2005
    hi all, me again
    new problem
    i was driving today, and the oil pressure guage is sitting on 4BAR at idle (was 3.75 yesterday)
    and at about 4.5 accelerating (was at 4.1 yesterday)
    it touched 4.75 BAR today
    the gregory manual says MAX OIL PRESSURE at 414kpa (4.14 BAR)
    have i got high oil pressure? is it an issue?
    first low pressure, now high
  21. #21
    Aug 2007
    sounds like a ****ty oil pump to me.
    The question about the light though, did you not say that it was on when the ignition was off?
  22. #22
    VN calais 91
    Aug 2005
    well, after driving it, its settled down, so i put it down to either dodgy wiring (my bad) or cheap gauge (not my fault)
    rockyvx, yes, it used to be on when ignition was off, then it started to come on only when ignition was on
    now its off as i disconnected it
  23. #23
    Aug 2007
    that sounds about right. But i'd blame it on the cheap gauge only
  1. Converting VR Executive light to a VR Calais interior light...
    By sverzijl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2006, 09:46 PM
  2. Engine Light and Trac Light
    By Quantum in forum General
    Last Post: 02-06-2006, 11:33 PM
  3. Replacing dash light AND radio light
    By CLE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-05-2006, 05:39 PM
  4. 'Rear light bulb failure' warning light
    By Misaprop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 03:07 PM
  5. VZ dash fog light warning light
    By Torquative in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-08-2005, 07:13 PM
