Results 1 to 5 of 5
Thread: Climate control
    Vn Commodore S pac.. MANUAL!!
    Sep 2007
    Endeavour Hills
    Default Climate control
    hey 2day is my first day so sorry if this has already been posted, but wot is required 2 put climate control into a vn s-pac?? anything would b helpful.. thanx
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    PM 1991_VN2NV, or 88GreenVN, they've both done this to their VNs.
    Going by both of their responses, its not an easy task. Doable, but only with alot of patience, as you have to rip the whole aircon system out
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Yeah, 88GreenVN transplanted a full loom into his car and I did a patch loom.
    You'll need climate loom, plug, HVAC box and all its bits and peices, sensors (both interior and exterior so ambient air temp sender and solar sensor), climate module, the climate resistor. You obviously have to remove the entire dash, remove the HVAC box and replace it, wire up the ambient temp sensor through the firewall, solar sensor in the demister vents etc. then patch the wires for the climate loom into your current loom if you do it my way which includes making a new fused connection, running a wire to your ECU and basically splicing a bunch of wires.
    Dash and Hvac box out:
    Putting the dash back in:
    PRH
    PRH is offline
    vp s utility,and a KENWORTH
    Apr 2007
    Mildura Victoria
    yeah i can vouch for the big job bit,ive just finished a conversion on me ute stato dash/console/climate control/elec windows/mirrors ect.
    I used the stato lume complete and removed the rear section which went to the rear doors,the only trouble i have now is the driveres door does'nt want to unlock with the key,and the central locking do'nt work,thought maybe this is because the alarm could be turned off ?
    Phillip
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    thread stealing, but has anyone come across the screen on the climate control not working, i have changed the climate control module wth a working one and it still doesnt work on my system.
  1. vs climate control
    By frenzal_tom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-10-2009, 10:59 PM
  2. WH Climate Control
    By mattman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-09-2007, 10:01 AM
  3. Climate Control
    By raZel in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-09-2006, 07:59 AM
  4. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
  5. Climate Control?? VY
    By aperfectcircle in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-01-2006, 12:13 AM
