Results 1 to 6 of 6
Thread: low or high pressure fuel pumps
    VE SS SPORTSWAGON
    Jan 2006
    Warwick
    Default low or high pressure fuel pumps
    can someone clear this up for me, im a little confused. do the vns have 2 fuel pumps fitted? or do some have a low pressure fuel pump and some have a high pressure fuel pump with a damper. why would they do this?
    also what is the difference between a standard fuel tank and a long range tank?
    cheers,
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Ahh yes. The standard tank (generally found on V6s) had one internal pump. The v8s generally had the long range, larger-capacity tank, and two fuel pumps.
    Two pumps for the 80 litre tank
    One pump for the 63 litre tank
    edit: although I do believe some early V8 VNs had an 85 litre tank
    The 1972 HQ Kingswood
    VE SS SPORTSWAGON
    Jan 2006
    Warwick
    cheers, clears a lot up. would you know the standard fuel pressure to the single pump v6s? trying to find an external pump
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Any external pump that is suited for an EFI system will work as the pump will have more than enough pressure for the system. The regulator takes care of any excess pressure. I think they run at around 50psi at WOT. EFI pumps run at more than that.
    Visit my Facebook page
    VE SS SPORTSWAGON
    Jan 2006
    Warwick
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    no thats an in the tank petrol cooled one just try find a vl commodore pump buy new they dont last forever
  1. genuine VN to VS high pressure external fuel pump
    By Boonz in forum Parts And Other Items For Sale
    Last Post: 10-05-2008, 01:46 PM
  2. Holley high pressure fuel regulator
    By Dan355 in forum Parts And Other Items For Sale
    Last Post: 18-10-2007, 11:19 PM
  3. Bosch High Pressure Fuel Pump Kit Brand New For VP Commodore
    By Cobez in forum Parts And Other Items For Sale
    Last Post: 26-09-2007, 06:23 PM
  4. how to disconnect high pressure fuel lines?
    By TheIceman in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-04-2007, 10:35 AM
  5. LPG fuel pressure way too high in Converter
    By Nancy Boy in forum General
    Last Post: 03-12-2005, 08:53 PM
